Author Topic: Irritating MSVC compiler behavior with arrays  (Read 5568 times)
« on: 2010 December 15 07:44:15 »
Hi guys
There are some times when I need to make an array with a constant length, but that depends on the image dimensions, or other parameter. For example, this:
int n = image.Width();
float vector[n];
While this compiles (and works) well under Linux, MS refuses to compile it. Most times I just avoid using standard arrays, and just create a Array<float> object, but I have I case where for compatibility issues with other libraries, I'm forced to use that kind of arrays. Do you know of other workaround, rather than using a large number?
Re: Irritating MSVC compiler behavior with arrays
« Reply #1 on: 2010 December 15 07:49:27 »
Hi Carlos,
arrays in C++ are basically pointers to memory. So you can malloc the appropriate amount of space, point to it and then use array notation to access it:
float *ar;
ar = (float*)malloc(n * sizeof(float));
ar[0] = 0.1;
ar[n-1] = 2.3;
free(ar);
ar = 0;
etc.
I'm sure C++ purists would insist that you use array templates or classes instead but this (or something similar) should work.
« Reply #2 on: 2010 December 15 07:55:53 »
I'll try that :D thanks
« Reply #3 on: 2010 December 15 18:23:16 »
It worked like a charm ;) thanks again!
Offline zvrastil
    • Astrophotography
« Reply #4 on: 2010 December 15 23:14:29 »
Hello Carlos,
you can also try little bit less-C and more-C++ way:
float* vector = new float[n];
delete []vector;
There are two differences:
1) It's IMHO much more readable.
2) In case array type is not basic type (like int, float, double) but a class, using delete [] operator ensures calling destructor for each class instance in the array.
regards, Zbynek
« Reply #5 on: 2010 December 16 02:29:00 »
I fully agree with Zbynek in the advantages of the new and delete C++ operators over the C malloc/calloc/free allocation scheme. That said, knowing and understanding standard C allocation is absolutely necessary IMO to gain the required perspective, even if we are using C++.
If you are using PCL, my recommendation is to use the GenericVector<T> template class (see pcl/Vector.h). GenericVector<> is a lightweight yet powerful implementation of a list of items of constant length. It uses shared memory (reference counted, so you can return it as a value from a function for example) and is thread-safe (you can use a single vector from several parallel running threads).
If you want to use fixed-length sequences of float, then you should use the FVector template instantiation. For example:
FVector a( 10 ); // a vector of 10 float components
FVector b( 10 ); // another one
a[3] = .123F; // implements array subscript operators
b *= 4; // implements scalar-assignment operators
FVector c = a + b; // implements vector algebra
float d = a * b; // dot (scalar) product
FVector c = FVector( 1, 2, 3 ) ^ FVector( 4, 5, 6 ); // cross (vector) product
... and so on. If you have to interface with C libraries, it is also very easy. Just use the FVector::Begin() member function, or —more elegantly— FVector::operator *(). Both members return a pointer to the internal array of floats stored in the FVector object.
« Reply #6 on: 2010 December 16 06:16:08 »
I'm passing the arrays to C++ functions, defined by CMinPack. So, I have not much space here to try other things :P
BTW, Juan, I'm sending to you the whole "Calcium" module at the current state (v1.1). I think it has some cool stuff inside that may inspire you to do other new processes for PI ;).
