Author Topic: Display mode gets reset after process mask preview  (Read 4722 times)
Offline David Serrano
« on: 2007 August 31 14:51:26 »
- Create a preview of an RGB image.
- Switch to it.
- Select luminance as display mode.
- Open ACDNR and enable the luminance mask. Disable the crominance noise reduction entirely.
- Apply to the preview. The display mode remais in Luminance of course.
- In the "Luminance mask" section of the ACDNR interface, enable the Preview checkbox.
- Apply the process to the preview again. The result will be the luminance mask that will be used during the ACDNR.
- Disable the Preview checkbox.
- Apply again. Now the display mode switches to RGB. I expect it to remain in Luminance.
This could happen with entire images (not just previews), and with crominance too... but I'm feeling kinda lazy to try it now. Maybe later, when I defeat this ACDNR monster :^P.
 David Serrano
Re: Display mode gets reset after process mask preview
« Reply #1 on: 2007 October 12 09:21:08 »
Quote from: "David Serrano"
Yes it does.
When working with images, it's necessary to undo the steps 5 and 7, given the different nature of images and previews. The problem manifests itself when undoing the step 7; you don't need to perform steps 8 and 9.
 David Serrano
