regarding HDRWT, in these photos I would use fewer layers... about 4. See the attatched photo. Another good practice is to activate the "Preserve hue" checkbox. HDRWT changes the hues of the pixels if applied to each separate RGB channel, because it normalizes the local hues; in other words, the hue of one pixel is determined by the average hue of the adjacent pixels. In astronomy this makes sense because you use to have several layers of dust, gas and unresolved objects. In this situation, a small O-III structure inside a huge and bright H-alpha emitting object will look red; HDRWT will recover the teal color of that structure. Think if this makes sense in your flower photos.
Keep in mind that HDRWT and ATWT are opposed algorithms. HDRWT is a dynamic range compression algorithm, and this means that contrast is always lowered; ATWT is used to enhance local contrast. So usually you will need curves or ATWT after application of HDRWT.
Vicent.
