Hi NKV,
I can see those bright lines in your screenshot both above and below the actual data. In the meantime, I have also been able to produce them Inrfan 4.23, see screenshot below. In Irfan, you have to deselect "Options/Properties+Settings/PlugIns/Load Half Size Image", which by default is on.... Given that Irfan, MaximDL and PI all see those bright lines, it appears that this is not a PI issue, more likely something in dcraw. Lucky Juan...
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
What I definitely dont see in PI or Irfan are those dark areas at the borders of you screenshot. If this is real sensor data, only without light, then these would be overscan areas that would be interesting for image calibration.
Does anyone have information on that? NKV: Does it look like real sensor data to you (i.e. with noise, with a few hot pixels, with the same "color" as the main sensor area in dark frames)?
