you can also transfer the white balance (asuming that atmospheric extinction is about the same in both images) of the galaxy image to the nebula one. When you do the color calibration of the galaxy image, the console outputs the RGB weights. You have two options to transfer these weight to your nebula image:
- In CC, put the white reference as your galaxy image. Instead of applying the color calibration to the galaxy image, apply the instance over the nebula image.
- Use the console weights in PixelMath to multiply each color channel of your nebula image. After this, make a background neutralization.
As an example, I've done the color calibration of this image:
[the greens are from a bad background neutralization, not from color calibration]
Taking as a white reference this image:
Vicent.
