Author Topic: Pixinsight Workflow  (Read 11128 times)
Re: Pixinsight Workflow
« Reply #15 on: 2010 October 04 13:06:00 »
Is it possible for DBE to 'clip' an image? I did a DBE on M33 and the histogram seems to be lopped off. Granted I did not do due diligence in my background modeling ... most of the frame is galaxy and points that are arguably not background were likely included in the model.
This is the reason I always advise folk to 'examine' the 'background image' that has been subtracted as a result of the DBE process - and it will take an aggressive STF or HISTO stretch to bring out the details of what has been 'removed'. Providing that you feel comfortable with what has been removed then, yes, although the image has most likely been clipped - the pixels that have been clipped are not identifiable as 'structure' in the original image.
Remember, DBE is always under the user's control, even if the user may not actually BE in control ::) So, if you don't like what was removed, it's probably time for a CTRL-Z on the original image - but 'save' the current DBE process as a ProcessIcon, just in case you change your mind. Then RESET the DBE process, completely, and run it again and see if things work better. Try it a few different ways, and settle on the one 'you like the most'.
And, always bear in mind that LESS can sometimes be MORE - so don't always be tempted to overdo DBE
Offline Luigi
« Reply #16 on: 2010 October 04 13:14:31 »
I should have made sure the background model was correct. My only excuse is that I was excited as these were the first images from the new camera  :)
I shall go back and rein in all those 'spurious' points. Thanks.
Luigi Marchesi
Offline RBA
    • DeepSkyColors
« Reply #17 on: 2010 October 04 20:56:17 »
My suggestion - which isn't better nor worst than Niall's, just different - would be not to reset the parameters. By adjusting the parameters, adding/removing samples, etc. you can influence the resulting background model gradually until you get what you believe you need.
A start over to me is more like "ok I'm way off, let's have a clean start" (which does happen) but then after the start over, I would again go on readjusting things if the new parameters/samples still don't cut the mustard.
Anyway, just sharing experiences. By no means I mean that Niall's suggestion is a bad one, but that in my experience, such reset isn't always necessary. And as always, your mileage may vary  :)
« Reply #18 on: 2010 October 04 23:38:56 »
Agreed with Rogelio - it isn't always a 'Reset' - sometimes it is more of a 're-think' when it comes to re-applying a process
Offline Nigel Ball
    • Astrophotography by Nigel
« Reply #19 on: 2010 October 05 03:43:15 »
This is essentially the process I have 'homed' in on.
My DBE is an iterative process.
  • Do an initial run of DBE
  • examine the Background at Auto STF
  • What does the Histogram look like? Is it okay?
  • If not then add/remove samples and re run DBE
As I said it is an iterative process
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
