Author Topic: Darks  (Read 7615 times)
Offline papaf
Darks
« on: 2010 October 01 00:57:19 »
Hi all,
the next week I'll speak at my local group about PI and how a magnificent program it is... ;)
The situation I'm in is a bit difficult, though: I always used PI with my ccd, which is cooled, sony based and b/w. I'm going to show PI to people who has DSLRs or OSC ccd. I wanted to talk about how PI handles darks, among other things, and I just discovered the very clever way in which PI determines if the dark should be stretched/adjusted to match different lenght/temperature of the exposures.
First question is: did I get it right? Is it true that darks can be taken in a different moment and at a different temp and PI will magically adapt the master dark to the light frames?
Secon: if I got it right, what's the better way to shoot darks? I know it would be better to shoot them right in the middle of lights, but let's assume we're lazy and we're going to shoot them in another occasion. Is it better to take them in the worst possible way, so say room temp? And what exposure lenght?
Thanks!
Fabio
Offline Emanuele
Re: Darks
« Reply #1 on: 2010 October 01 03:46:16 »
Fabio:
Darks should be taken at the same temperature and with the same exposure lenght of the light frames.
They don't have to be taken in the middle of taking the lights.
PI and other programs are able, through the use of Bias frames, to scale the darks to match the exposure length and noise of the Light frames. BUT in order to do that the darks need to be longer than the light frames.
Eg. Take darks Of 1800sec. Take Bias frames (150-200). Then use the Bias and the Darks to calibrate light frames (of less than or equal to 1800sec)
Hope this helps. Others will chime in.
Offline Nigel Ball
    • Astrophotography by Nigel
Re: Darks
« Reply #2 on: 2010 October 01 04:27:45 »
Fabio
When I got my QSI camera the first task I did was to create a library of darks at my target temperature with is -20°C. Emanuelle is correct darks do not have to be taken in the middle of lights with temp controlled CCD cameras
Bias frames will be applicable for around 6 months.
HTH
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline papaf
Re: Darks
« Reply #3 on: 2010 October 01 05:03:44 »
Thanks for the replies. You two kind of seem to throw water to the story, which I read in a page Juan wrote a while ago to explain how PI was handling the darks. From this page, Juan seems pretty sure about his algorithm, but you two sound pretty cautious.
I know darks should be taken every time, and I also know about taking them at fixed temp. But we're talking DSLRs and beginners, with not much time available for shooting. So I was exploring alternate routes to use darks. I don't pretend to have the absolute best performance out of them, but maybe to offer them a viable solution.
In any case, E. kind of answered it. Darks have to always be as long or longer than light subs. That's a start!
Fabio
Re: Darks
« Reply #4 on: 2010 October 01 06:59:22 »
Hi Fabio
What I do (before PI's method, but this works fine) with my Canon 300D is to take darks to match the longest exposition time. I really don't care too much about temperature. Usually I do them at the end of the night, start nearly at dawn, and I leave the camera and laptop taking the darks for one or two hours, well covered.
Since what we are trying to capture with darks is the underlying "signal" due to temperature, more time implies that you'll have better SNR. So, to better represent the true dark signal, I would keep using my rule of thumb. Scaling down a well sampled signal is easy. Doing the opposite may produce ugly results.
Offline Harry page
Re: Darks
« Reply #5 on: 2010 October 01 07:47:04 »
Darks what are they  >:D
Oh a very happy starlight xpress customer
Harry
I know not much help , but it cheered me up  ;D
Harry Page
Offline DaveS
    • Dave's Astronomy Pages
Re: Darks
« Reply #6 on: 2010 October 01 07:52:34 »
I gave up taking darks a long time ago, as with the very low dark current of SX cameras, they just aren't necessary.
That said, I always subtract a Bias frame, which if you do take 'darks', isn't necessary, as the Bias data in contained within the dark frame.
Dave
8" LX200ACF
William Optics FLT110
NEQ6 Mount
SXVF-H9
SXVR-16
SX Lodestar
DMK21AU04
Baader LRGB and NB filters
DiY Observatory
http://www.progressiveastroimaging.com/davesastronomy/
Re: Darks
« Reply #7 on: 2010 October 01 10:14:14 »
Bias are always necessary, if you are taking flats ;)
Offline papaf
Re: Darks
« Reply #8 on: 2010 October 01 10:55:04 »
Harry, I have a sony based Atik camera so...  >:D hell yeah! High five!
But, I do have to come up with something for my fellow dslrs users! What Carlos said is what I had in mind. Maybe one could simply put the camera outside on a middle week evening and capture just darks, right?
About biases: I thought I read bias are also used with darks. Am I wrong?
Fabio
Offline Emanuele
Re: Darks
« Reply #9 on: 2010 October 01 10:57:27 »
The Bias is already contained in the Darks. Bias are only used to scale darks and for Flats.
Re: Darks
« Reply #10 on: 2010 October 01 11:03:20 »
Yes, as Emanuele said, Bias are needed to rescale darks too. So, at the end, just take them. After all, it is pretty cheap to do :D
Offline Nigel Ball
Re: Darks
« Reply #11 on: 2010 October 01 12:08:05 »
This is pretty much what I used to do with my Canon 1000D. At the end of the nights imaging I would set the DSLR running to take a batch of Darks equal in lenght to the Lights
Nigel Ball
www.nigelaball.com
astropixel
  • Guest
Re: Darks
« Reply #12 on: 2010 October 01 17:50:53 »
Hmmm... this may be the answer to a question in another forum and possibly the source of earlier processing issues.
Frankly, I took darks and lights of the same exposure time, and took only 10 bias and 10 darks. Whether it matters or not, I don't know, but I took 10 flats. It seems to work OK.
Re: Darks
« Reply #13 on: 2010 October 02 09:16:16 »
Carlos said:
Not if you have taken FlatDarks at the same temperature and exposure time as your Flats :P (as, then, you can use the FlatDarks without worrying about Biases)
(Similarly, Biases are not needed if you take Darks at the same temperature and exposure time as your Lights)
SX users claim that they never need to take Darks - yes they do, if only to prove to themselves that a MasterDark is an ABSOLUTELY IDENTICAL image to a MasterBias - i.e. if you took 30 Darks (at the same exposure time and temperature of your Lights, say 5 minutes at -20C) and 30 Biases (at minimum exposure time, and also at -20C), and then created a MasterDark and a MasterBias using the same steps in each case, and then DIVIDED the MasterDark by the MasterBias (or subtracted one from the other) then the result should be an image with nothing but '1.0000' for the DIV process or '0.0000' for the SUB process. And I have yet to see THAT result demonstrated to me by anyone - fancy giving it a go Harry? It's a nice exercise for a cloudy night!!!
Re: Darks
« Reply #14 on: 2010 October 02 16:50:45 »
Since darkflats are almost the same as bias, I'd call them bias :D
