Author Topic: Cannot locate Scripts  (Read 10111 times)
Offline Nigel Ball
    • Astrophotography by Nigel
« on: 2010 September 24 13:37:40 »
Another problem with my install after buying the licence
PI cannot find the scripts. It appears to be looking in ProgramFiles/Pixinsight/PCL/Src/Scripts
and not PCL/Src/Scripts
Is there a registry key or environmental parameter which is incorrectly set?
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Re: Cannot locate Scripts
« Reply #1 on: 2010 September 24 13:39:51 »
Did you install PI in the recommended c:\pcl location?
« Reply #2 on: 2010 September 24 13:58:20 »
I think I remember reports that PI has difficulties if installed on a path that contains space characters, such as "Program Files". I usually install at the default location ("C:\PCL"), and this works fine.
Offline Nigel Ball
« Reply #3 on: 2010 September 24 14:05:27 »
Sander/Georg
PI is installed in c:/PCL - see screenshot
For some reason PI is looking in programFiles etc for the scripts? I think the Trial may have installed in ProgramFiles folder to the Windows standard and this is what may be causing the problem ......
Nigel
Nigel Ball
www.nigelaball.com
« Reply #4 on: 2010 September 24 14:07:21 »
Hi Nigel,
sorry, I didn't notice the explorer window. I don't know how to fix this, sorry. Be sure to send an email to 'support@pixinsight.com'.
« Reply #5 on: 2010 September 24 14:41:41 »
I think that there was not a clean clearup of the settings. Restart PI with the Ctrl key pressed. This will launch the "settings cleaner utility". Try this, althoug you'll loose previous configurations.
« Reply #6 on: 2010 September 24 14:44:43 »
There's also a 'reset pixinsight settings' start menu item on windows.
Offline Nigel Ball
« Reply #7 on: 2010 September 24 16:17:32 »
Thanks Carlos
That has fixed the problem  :D
Nigel
Nigel Ball
www.nigelaball.com
« Reply #8 on: 2010 September 24 17:01:50 »
thumbs up :D
« Reply #9 on: 2010 September 29 03:53:03 »
Hi Nigel,
I think this problem was related to the strange license activation problem you had before. For some reason things got messed up in an odd way. As Carlos and Sander have noted, the standard solution to these problems is resetting PI's configuration (launching with Ctrl pressed is a useful backdoor). However, this certainly should not happen. I'll take a good look at the installation and activation routines before the next release.
On the other hand, installing on an arbitrary directory is (should be!) perfectly possible and should cause no problems. However, the standard C:\PCL (C:\PCL64) location is recommended. Anyway, PI installations and directory trees will change in the near future, so we'll have new issues... :)
Offline Andres.Pozo
« Reply #10 on: 2010 September 29 04:28:44 »
That is not the usual behavior of Windows applications. Since it can work without problems from $(ProgramFiles)\PCL, why does PixInsight default to installing in C:\?
If every application did that, the root of the disk would be a chaos!!
« Reply #11 on: 2010 September 29 07:22:30 »
Because we are special ;)
More seriously, having PI close to the root is convenient for developers.
« Reply #12 on: 2010 September 29 07:48:07 »
Even more seriously, people develop on Windows all the time and they don't require Visual Studio to be in the root :)
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« Reply #13 on: 2010 September 29 08:09:51 »
Personally, I have a PI installed into a subdirectory (exclusive for all astronomical applications), and it works perfectly.
« Reply #14 on: 2010 September 29 08:15:18 »
Developing in windows is not serious development ;) LOL
I said convenient, not required :)
