www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Luminance mask and Sh2-142 help required
« previous
next »
Print
Pages: [
1
Author
Topic: Luminance mask and Sh2-142 help required (Read 3788 times)
Redshift
PixInsight Enthusiast
on:
2010 September 23 11:10:14 »
Hello,
I'm processing Sh2-142 the Wizard nebula. I've stretched the main part of the nebula and I now want to reveal more of the wispy stuff that surrounds it. I've made a Luminance mask and applied it to the main image and then inverted it. I can see that the mask appears to be protecting the main part of the nebula and stars. But when I do a Histogram Transformation it still stretches all of the image.
I wondered if anyone could offer any guidance to where I'm going wrong?
Thanks in anticipation
Dave
Logged
My blog
http://dasdaveadshead.blogspot.com/
lucchett
PixInsight Old Hand
Re: Luminance mask and Sh2-142 help required
Reply #1 on:
2010 September 23 13:49:53 »
Hi, may be the mask is not strong enough?
you could binarize it and see if that is the problem.
May be is not the best way, but i prefer to apply curves where i fix the intervention values, masking only the stars if necessary.
Andrea
Logged
Carlos Milovic
PTeam Member
PixInsight Jedi Master
Join the dark side... we have cookies
Reply #2 on:
2010 September 23 13:57:30 »
1.- Check that the mask is enabled
2.- Check the console output, if there is feedback from the masking process.
If both tests pass, then there may be something wrong with the mask itself.
Logged
Jack Harvey
PTeam Member
PixInsight Padawan
Reply #3 on:
2010 September 23 13:59:38 »
Try this and make the mask stronger as mentioned above.
Open your Wizard color image and clone it by click and hold on the name and drag it to the right. Now open ACDNR and in the bottom of the tool check Preview on Luminance Mask and enable the real time preview button (be sure the cloned image is selected in the dropdown) on the bottom. Adjust the Midtones for the amount of masking you wish to have applied (you monitor this in the Real Time Preview Window). You can also adjust shadows and highlights to fine tune the mask. Now drag the triangle in the ACDNR tool onto the
cloned
Wizard image. Now you have the mask to apply to your original Wizard image. Proceed with histograms or curves to bring out the dim area. WHen finished remove mask.
Logged
Jack Harvey, PTeam Member
Redshift
Reply #4 on:
2010 September 24 02:44:41 »
Andrea and Carlos,
Thank you. The mask wasn't strong enough, I made it stronger and got results.
Jack,
I tried your method as well, that worked also.
I now need to learn how to refine them.
Thanks and regards
Dave
Logged
My blog
Print
Pages: [
1
« previous
next »
PixInsight
General
