Author Topic: After switching readout mode to integer it won't go back to real?  (Read 4918 times)
I switched readout mode to 0-64k and then back to real 0-1. Readout values change to the integer values fine but then remain at 0 after switching to real.
Re: After switching readout mode to integer it won't go back to real?
« Reply #1 on: 2010 September 26 08:02:19 »
I also have this problem.
« Reply #2 on: 2010 September 26 09:11:05 »
It seems Juan has gone undercover somewhere in wine country.
« Reply #3 on: 2010 September 26 09:31:15 »
Hi Sander,
I am not seeing this - and I am also using Vista64.
Maybe I am not fully understanding your scenario (same with you, Georg)
When I click the little blue triangle on the bottom bar of the PI window, I have the following options:-
The setup I am currently using, for each of these options, is as follows:-
Readout Data
Readout Mode
Probe Size
Preview Size
Preview Zoom
And, this is what I use if I want to see ADU data in terms of a 16-bit Unsigned Integer range (0, 65535)
And I use this for my PixInsight 'internal' (0.0, 1.0) range
I can change happily, back and forth, between these two configurations without any 'bug' being evident, either on the display line at the foot of the PI main window, or on the 'readout probe' panel when actually inspecting an image, as shown in the two examples below:-
  Real Mode
  Integer Mode
Have I missed the point of your bug reports?
« Reply #4 on: 2010 September 26 09:36:23 »
You're getting close. Now change back to range 0-1 and see if you're getting fractional numbers or just 0 with the occasional 1 if the data is maxed out.
« Reply #5 on: 2010 September 26 09:41:10 »
Hi Sander,
Yes - that WAS what I noticed, but I simply took that to represent a REAL display with 'zero' decimal places - in the same way as I have interpreted each of the other 'real' options to represent options of between 1 and 15 decimal places.
I agree, this is perhaps not that intuitive - at first - but, isn't that the way of PI  ::) ;)
What I cannot remember is how 'it used to be' and 'when it changed'. I have a feeleing that this changed well before v1.6.x - but I may be wrong
So, 'bug' or 'feature' ???
« Reply #6 on: 2010 September 26 10:48:44 »
Hmm, I'll have to play with this a bit more. I couldn't get it to do the right thing anymore but that's probably because I don't understand the options. Of course there's no help for them so I suppose we should just figure it out ourselves.
« Reply #7 on: 2010 September 26 15:29:55 »
You couldn't get it to do the right thing or you couldn't get it to do the wrong thing any more?
As I said, I now interpret the 'Real' options to allow me to choose the number of decimal places for displaying my ADU values - all in the range [0.0, 1.0] of course. And the choices are from 1e0 through to 1e-15, or no decimal places through to 15 decimal places - which does actually make sense (apart from the rather un-necessary first entry).
Perhaps it would be better actually just stating "number of decimal places" in the options list - it would avoid confusion ::)
« Reply #8 on: 2010 September 29 04:11:27 »
Hi Niall,
Actually, it is more related to the precision of the decimal representation (not to be confused with accuracy; the accuracy is always the same in this case).
Following your suggestion, I'll change this menu to:
0 decimal places
1
2
15
« Reply #9 on: 2010 September 29 04:13:05 »
Yeah, I always do that while I'm writing a documentation compiler  :laugh:
« Reply #10 on: 2010 September 29 06:06:15 »
Thanks Juan, that will make the radout options clearer. I think what happened was I changed one option and I had to change two to get back to where I started.
