Author Topic: Morphological Transformation (MT)  (Read 5547 times)
Offline Nigel Ball
    • Astrophotography by Nigel
« on: 2010 September 17 08:22:26 »
I've been using MT to reduce star sizes and hence enhance the nebula - particulalry for my wide field Veil shots I'm working on wheer there are a lot of stars 30 min subs in Ha and OIII)
Some of my old images have elongated stars in the the corners (sometimes only one corner). I was wondering if I can use MT to correct this elongation but only in one corner. The Star Mask seems to cover the whole of the image.
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Re: Morphological Transformation (MT)
« Reply #1 on: 2010 September 17 09:18:50 »
I learned this trick from Juan, of course  ;)
You can use PixelMath to create a gradient image, and use them as a mask. I attached a screenshot and the PM process icon (right click, Process Icons > Load Process Icons to open it). In this example I create an greyscale image of 800x600 px, with a gradient from bottom right and 800 px radius. You can modify this variables in the Symbols field (cx, cy, r) to create you own mask.
I hope it helps.
Enzo.
Offline Nigel Ball
« Reply #2 on: 2010 September 17 09:44:15 »
Thanks Enzo
This is very helpful to me  :D
Nigel
Nigel Ball
www.nigelaball.com
« Reply #3 on: 2010 September 22 07:05:43 »
Hi all,
For those of you who perhaps didn't see this thread earlier, there is an excellent reply from Juan about creating 'clever' area selection masks:
http://pixinsight.com/forum/index.php?topic=2165.0
Hope this helps
