Author Topic: Combining Ha and OIII  (Read 4951 times)
Offline Nigel Ball
    • Astrophotography by Nigel
« on: 2010 September 11 08:17:33 »
Hello all
I've been happily processing my Ha and OIII subs in PI and I've even saved my first Process Icon  :D The Morphological Transformation tool wokred overtime on this wide field shot .....
Once I've got the images ot a decent state I'll want to combine them into RGB and generate a synthetic Green channel or create one using the Ha and OIII
I've had a good look through the forum but cant seem to find anyhting on this
Any thoughts / directions ?
Nigel
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Silvercup
Re: Combining Ha and OIII
« Reply #1 on: 2010 September 11 10:58:57 »
Hi Nigel:
I used to do this pixelmath expresion:
R: H-Alpha
G: sqrt(H-Alpha*OIII)
B: OIII
Or you can play with percent in the green channel, for example:
R: H-Aplha
G: H-Alpha*0.15+OIII*0.85
B: OIII
Best. Silvercup
Offline Nigel Ball
« Reply #2 on: 2010 September 11 15:22:18 »
Thanks Silvercup
My first attempt produced a rather dirty yellow for the Ha using 0.8 Ha + 0.2 OIII  :-[
I'll need to tweak the ratios to get a decent colour
Would I use PixelMath again to add the Ha on top of a RGB image for Luminance?
So many questions .....
Nigel
« Last Edit: 2010 September 11 17:16:27 by NigelB »
Nigel Ball
www.nigelaball.com
