Author Topic: Updated Module: ColorCalibration (New LinearFit tool)  (Read 8170 times)
« on: 2010 September 10 04:13:38 »
Hi all,
A new version of the standard ColorCalibration module is now available for all supported platforms. This version includes the new LinearFit tool, a robust, high-precision calibration tool that performs a linear fit to match mean background and signal levels between two images.
For a detailed description of the LinearFit tool and its applications, see the corresponding thread on the Release Information forum board.
1. Installation Files
ColorCalibration Module
2. Installation Instructions
All platforms. If you have one or more instances of the PixInsight Core application running, terminate all of them.
FreeBSD and Linux. Download the tarball (for example, with wget) for your machine architecture, uncompress it and copy the resulting -pxm.so file to your bin installation directory. For example, assuming you've installed PixInsight on a 'PixInsight' directory under your home directory:
cd ~
mkdir tmp
cd tmp
wget http://pixinsight.com/download/modules/20100910/ColorCalibration-bsd-x86_64.20100910.tar.gz
tar -xzf  ColorCalibration-bsd-x86_64.20100910.tar.gz
cp -f ColorCalibration-pxm.so ~/PixInsight/bin
Windows. Download the compressed file (a standard zip file) for your architecture (x86 or x86_64), uncompress it, and copy the resulting -pxm.dll file to your bin installation folder. If you haven't changed it during installation, your bin installation folder is C:\PCL\bin (c:\PCL64\bin for 64-bit versions). Replace the old ColorCalibration-pxm.dll file.
Mac OS X. Download and uncompress the zip file for your architecture (x86 or x86_64). This will create an 'ColorCalibration-pxm.dylib' file. Locate the PixInsight.app application bundle with Finder. Normally, you should have it on your standard /Applications folder, although PixInsight.app can be executed from an arbitrary location. Right-click on PixInsight.app and select 'Show Package Contents'. Now open the Contents/MacOS folder and copy the new 'ColorCalibration-pxm.dylib' file there, replacing the existing file.
Hope you like it. Enjoy!
« Last Edit: 2010 September 12 15:37:46 by Juan Conejero »
Offline Jack Harvey
Re: Updated Module: ColorCalibration (New LinearFit tool)
« Reply #1 on: 2010 September 10 06:42:17 »
The Mac links do not get me to the download?
Jack Harvey, PTeam Member
« Reply #2 on: 2010 September 10 10:25:00 »
Hi Jack,
My mistake. The links work correctly now. Thanks!
Offline Jack Harvey
« Reply #3 on: 2010 September 10 13:32:24 »
Really  When I click the 64 bit Mac link I get an blank untitled page and url that says go to this address.  The other modules are the same, so I am unable to download any of the four modules.
« Last Edit: 2010 September 10 14:18:15 by Jack Harvey »
« Reply #4 on: 2010 September 10 14:38:59 »
Hi Jack
The links are working fine here (Fedora+Firefox)...
Offline sleshin
« Reply #5 on: 2010 September 10 15:40:04 »
Juan,
Please clarify, is this a new Color Calibration or an Image Calibration module.  In your post the downloads are listed as Color Cal but in your instructions you state "Replace the old ImageCalibration-pxm.dll file."
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline Luigi
« Reply #6 on: 2010 September 12 09:16:57 »
No soy Juan, pero  ;)
Looks like a copy/paste error. The archive contains the ColorCalibration module. Leastwise the Windows 64-bit version does.
Luigi Marchesi
« Reply #7 on: 2010 September 12 15:40:01 »
Hi Steve,
Sorry, my mistake. It is the ColorCalibration module, not ImageCalibration; I've just corrected the announcement post. Yes, a copy/paste error... :)
Offline mmirot
« Reply #8 on: 2010 September 13 05:06:59 »
We could use some orientation on this one.
Max
