Author Topic: Saving profiles?  (Read 12913 times)
Offline Zie
Saving profiles?
« on: 2005 January 04 20:49:28 »
In a way, this is both a request for help and a suggestion. I'm looking for a way to save the SGBNR settings I used on a particular image (I am using PixInsight LE 1.0.1.141). I went ahead and saved a report to a file, but having to manually re-enter the data is tedious. Is there some kind of save button on the SGBNR process window, or am I missing something? The previous beta versions of SGBNR had a button on the same window to save the settings you were using.
    I also tried fiddling with the "Save process icons," but can't seem to get it to pick back up my settings. Perhaps you could add one of these to the process window?
Thanks for your help
Re: Saving profiles?
« Reply #1 on: 2005 January 05 02:26:07 »
Hello Zie,
Welcome to PixInsight Forum.
Definitely process icons are what you're looking for in PixInsight. These are the main steps:
1. Create icons
Once you have a set of SGBNR parameters that you want to save, create a process icon from the SGBNR window. This is very easy: click on the small button labeled "<" at the bottom left corner of the window (which we call "Process Drag Object"), and drag it to the main window's background. This will create a new icon with the set of SGBNR parameters. Here is a direct link to the corresponding documentation section:
http://pleiades-astrophoto.com/pixinsight/help/11_process_icons/creating_process_icons/creating_process_icons.html#02
Note that you can repeat this as many times as you want. This means that you can create hundreds of icons, each one with a different set of parameters.
2. Rename icons (optional)
If you create many icons, perhaps you might want to give each of them a meaningful name (instead of Process01, Process02, etc.). Right-click on an icon and select "Set Icon Identifier":
http://pleiades-astrophoto.com/pixinsight/help/11_process_icons/managing_process_icons/managing_process_icons.html#05
Giving meaningful identifiers to icons is good practice. It will help you when you reuse the icons after some time.
3. Open icons
To open an icon, loading its parameters on the corresponding processing window, just double-click it. You can also drag it to the appropriate window if it is open.
4. Save icons to disk files
Process icons can be saved to special disk files that we call "Process Icon Set Modules". These files carry the ".pi-psm" file extension. To save all the currently defined icons, select "Process > Process Icons > Save Process Icons..." from the main menu. Alternatively, you can right-click on any free area of the main window's background.
5. Load icons from disk files
Use "Process > Process Icons > Load Process Icons...". You also have an equivalent option by right-clicking on the main window's background, as before.
6. Merge icons from a file with existing icons
OK, you have some good icons, and you want to (a) merge them with other ones that you have in an existing file, to keep all of them into a single file, or (b) you need to work with additional icons from a file, but you don't want to throw away the icons that you have currently defined.
To merge the contents of a .pi-psm file with the current icons, just press the Shift key while you select "Process > Process Icons > Load Process Icons...". The file's contents will be loaded but existing icons will not be deleted. You can then save the resulting set of icons to the same file, or to a new one.
Note that the above works with SGBNR and with any other process in PixInsight, in just the same way.
Note also that you can create icons of many different classes (processes) and save them to a unique file. There is no specific limit in the number or types of icons saved to .pi-psm files.
Process icons and process containers in PixInsight have been designed to maximize flexibility and versatility. Expect significant improvements in incoming versions, especially with respect to user interface resources dedicated to handle and organize them.
Hope this helps. Please let me know.
Small bug in the SGBNR window; have to take it into account
« Reply #2 on: 2005 January 05 02:43:45 »
Zie,
Just a brief additional note to say something that you should know.
In the latest versions of PixInsight LE, there is a small bug in the SGBNR window that we have discovered recently.
When you use the CIE L|ab or CIE L|a|b color models in SGBNR and create a process icon with the set of SGBNR parameters, the color model is not properly selected on the SGBNR window when you double-click on the icon.
For example, suppose that you define some SGBNR parameters in the CIE L|ab color model, then save them to a process icon, and save the icon to a .pi-psm file. Then you exit PixInsight. When you run PixInsight again, and load the .pi-psm file, the icon appears on the main window background, as usual. But, if you double-click the icon, the SGBNR window stays in the default RGB color model. All of your parameters have been loaded in the window, but you have to select the correct color model (CIE L|ab in this example) manually.
Sorry for the inconvenience; this bug will be corrected in a few days.
Offline Zie
« Reply #3 on: 2005 January 05 14:24:23 »
Got it. Thanks for the help; talk about great support :-)
