Hi Steve,Just combine all of them in a single operation. Use ImageIntegration and be sure that the Weights parameter is set to Noise evaluation (this is the default setting). Our noise evaluation image weighting algorithm will automatically multiply each of your images by the optimal scaling factor to yield the highest SNR improvement in the final result.If you have 25 images in total, I'd suggest the new linear fit clipping rejection algorithm. See this post for detailed information.
Juan - does this imply that using different length exposure subs with a weighting from sub frame selector that includes fwhm and eccentricity will not work and that unless noise evaluation is used only equal length subs should be used?
