Author Topic: Dealing with NaNs in a FITs image  (Read 3149 times)
Offline Joe DePasquale
« on: 2010 September 03 11:26:34 »
Hello all,
I've been using PixInsight for just over a year now as the Science Imager for the Chandra X-ray Observatory and feel like I'm just barely scratching the surface of what it can do.  One problem that I routinely run into when loading FITs files into PI is that images with NaN values fail to load.  I have a python script that converts those values to numbers so the images will load in PI, but is there another workaround for this?
Thanks!
Joe
Re: Dealing with NaNs in a FITs image
« Reply #1 on: 2010 September 03 11:32:41 »
Hi Joe,
Welcome to PixInsight Forum. Which version of PixInsight do you have? This problem is supposed to be fixed in version 1.6.1. In the latest version, non-numeric IEEE entities are replaced with zeros by the FITS and TIFF modules.
To check your current version, enter the 'version' command in the processing console window, or select Help > About PixInsight.
« Reply #2 on: 2010 September 07 07:01:43 »
Thanks for the quick response!  I do have version 1.6.1 and I guess I haven't tried to load this type of file since upgrading because it does work now!  What an easy fix :)  Thanks!
