Author Topic: grayscale batch conversion  (Read 14663 times)
Re: grayscale batch conversion
« Reply #15 on: 2010 September 04 07:49:50 »
Also, would you mind if I compiled this and the information from other posts (linked and referenced), just to consolidate the information in one place? Or at the very least, create a sticky that links to all the relevant posts
That would actually be very useful - collate all the data that you feel is relevant (quoting source or contributor as you feel necessary - even just referring to the original Forum thread number would be enough) and put it in the Tutorials or the Tips and Trick section as you see fit.
And, don't even worry if you don't get your facts 100% correct - it is often when the collated data is re-read that you and others will spot errors, or make suggestions for further improvements.
astropixel
  • Guest
