Author Topic: Dead Keyboard, while scripts are running  (Read 3513 times)
« on: 2010 August 26 14:55:58 »
Juan, you are gonna love this: the keyboard is often dead while PI is running (working, not just with the dialog window open) a script. This means, I cannot write anything elsewhere. I'm running Fedora 13 x64.
Re: Dead Keyboard, while scripts are running
« Reply #1 on: 2010 August 26 15:05:15 »
Probably running in realtime thread priority. At least that's how my PC used to behave when PI was being a bad citizen :)
« Reply #2 on: 2010 August 27 03:52:34 »
No, this has nothing to do with thread priorities; that problem is definitely gone since several versions on all platforms. That could only happen on Linux if he'd enabled real-time priority at a system-level on his machine, and even running at the highest priority the keyboard wouldn't be blocked but sporadically during a few seconds at most.
Anyway this has nothing to do with threads because it's happening during script execution, and scripts are single-threaded.
Pretty weird! On which machine are you running PI?
« Reply #3 on: 2010 August 27 06:50:09 »
By the way, yesterday the keyboard was dead during ImageIntegration (or ImageCalibration) too. So, this is not just script related, although there are very few times where a process generates that behavior.
I'm working on a dual 2 core processor, 2 or 4 Gb of Ram. Overall, is a fine machine ;) Having said that, I think that the monitor is stressing the system a lot, a 30" HP LCD, 2550x1900 px (of curse this is at work, not home! <vbg>)
« Reply #4 on: 2010 August 27 10:39:02 »
Open a terminal window and run the top command. Run PixInsight and while it is doing a heavy process, tell me what priority (PR column), processor usage, etc. top lists for the PixInsight process.
« Reply #5 on: 2010 August 27 12:11:03 »
Monday ;) I took the day off :D I'll be working today at home, updating process module codes and recompiling them with the new PCL.
