Author Topic: ImageIntegration, File Cache  (Read 3307 times)
Offline NKV
« on: 2010 August 22 09:07:57 »
Something wrong with the the File Cache. Possible wrong calibration, because lost Pedestal keyword sometimes.
Looking in my calibration library I don't found PEDESTAL keyword in some masters files, but really the pedestal added in to pixels data.
I got 3 different result playing cache buttons.
1
Total :    799644   0.952% (    44244 +    755400 =   0.053% +   0.900%)
** Warning: Inconsistent pedestal values detected - PEDESTAL keyword not created.
17.217 s
2
11.983 s
3
* PEDESTAL keyword created with value: 100.0000 DN
18.043 s
Result #1 it's bug.
Result #2 pedestal added, but no PEDESTAL Keyword in header.
Result #3 is OK. (use file cache disabled)
Best regards,
Nikolay.
PS PI 1.6.1 PCL Win7x64
Re: ImageIntegration, File Cache
« Reply #1 on: 2010 September 02 05:12:32 »
Hi Nikolay,
I have reproduced and found this bug. It's simply that the pedestal values are not being written to the file cache.
The workaround when you have to use pedestal values is, as you've discovered, disabling the file cache in ImageIntegration. Users that don't need pedestals are unaffected by this bug and hence don't have to care.
I'll try to release a new version of the ImageIntegration module as soon as possible, with this bug fixed of course. The next version will also include the new HDRComposition tool, which I'm writing right now.
Thank you for your bug report, and sorry for forcing you to disable II's file cache...
