Author Topic: Combining subs with different exposure times  (Read 4462 times)
Offline RobF2
  • Rob
    • Rob's Astropics
« on: 2010 August 21 04:10:30 »
I'm currently shooting Ha frames to go with LRGB data I collected at a dark sky site for M16.  I already have quite a few 5min shots, but the mount is tracking well so tonight I've been shooting 10min Ha subs.
I would normally stack the 2 stacks separately and look to blend them to taste/utility at the end (in Photoshop actually >:D  :-[)
What would happen if I just calibrated, aligned and integrated them in PI - any pros and cons?
Thanks all,
R
Rob's Astropics
Offline mmirot
Re: Combining subs with different exposure times
« Reply #1 on: 2010 August 21 05:21:52 »
Rob,
Just use noise evaluation weighting. It takes care of this problem automatically.
Max
Offline Harry page
« Reply #2 on: 2010 August 21 09:32:56 »
As said use the weighting option , I use this all the time even with exsp of the same length , it will give best results  8)
Harry
Harry Page
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #3 on: 2010 August 21 17:59:54 »
Thanks guys - looking at the process icon I've saved and usually start from I'm typically running on the following in the "Image Integration" section of the Image INtegration process:
Combination:   Average (or Median)
Normalization:  Additive
Weights:           Noise Evaluation
(with Generate integrated image and Evaluate Noise ticked also)
I'll give it a spin both ways and see what happens!  :)
Rob's Astropics
