Author Topic: HDR terrestrial photography settings/memory  (Read 3933 times)
astropixel
  • Guest
« on: 2010 August 21 04:04:51 »
Hi. I'm attempting to combine 3 Canon raw images to create an hdr image, using the HDR script. The images are large, 4032 x 3024. I've been able to produce one hdr.fit - good luck I think - all attempts otherwise failed. I've tried calibrated fit images, tiff and jpeg, but the process never completes and either freezes the desktop, produces a black screen or crashes Pixinsight.
I did think that this may be a settings problem, but I'm inclined to think it's a memory problem?
System is ubuntu Linux 64 bit, Dual Core 2.20GHz, 2GB RAM, swap 1.6GB.
Looking forward to resolving this... ...any ideas?
Re: HDR terrestrial photography settings/memory
« Reply #1 on: 2010 August 21 08:17:07 »
There are many reports of problems with the script (yeah, I think that it is memory related too). My suggestion, for the moment, would be to have a little patience and wait for the new process module that will be released soon. It will be faster, improved, and hopefully, without memory problems :)
astropixel
  • Guest
« Reply #2 on: 2010 August 21 12:58:21 »
Thanks Carlos - otherwise no complaints - fabulous program.
astropixel
  • Guest
« Reply #3 on: 2010 August 25 00:31:28 »
Are there any changes that can be made to the existing script in the short term, until the new script is available?
« Reply #4 on: 2010 August 25 04:55:23 »
I don't know... to be honest, I've never used the script :D (and I know very little about javascript... I work mainly with c++). I do the HDR combination manually. I described the process in spanish to Manolo. You may try a translator (babelfish or google) until I find time to do that.
http://pixinsight.com/forum/index.php?topic=2168.msg14207#msg14207
astropixel
  • Guest
« Reply #5 on: 2010 August 25 12:23:29 »
Thanks Carlos. I managed to translate your tutorial and will give it a go.
