Author Topic: Is anyone working on a script to support Vincent's tutorial on N-Band / B-Band?  (Read 9344 times)
Offline David Raphael
    • Astrofactors CCD Cameras
ahh...I just woke up and didn't read your first email quite right :-)
1.  The "broadband pedestal" helps get the continuum map calibrated.  I would start out with 0 here.  I might make that the default.
2.  The "continuum iterations" is the number of time the continuum map is recreated and multiplied iteratively against the N-Band
3.  The "Ha Boost Factor" is the number that the Ha data is multiplied by before being substituted into the HaGB image
Setting 1 is going to be removed.  I will write a routine to automatically set this value.  In the meantime, very small values need to be used here.  I've been getting decent results with .0001-.009 - but feel free to use different values here.  You can use negative values - if this improves the result let me know that especially.
Thanks so much for trying this out!
Dave
David Raphael
Has anyone been able to use this script with any degree of success?
David Raphael
Offline RickS
I tried the script tonight and it did some odd stuff but sort of worked.  The "FinalCombo" image appears to have been created but I can't find it.  I can redo the final ChannelCombination operation and I do get an image that looks vaguely like it should after I remove the background, but not that great.
I played around with the script a little and compared it with the results of trying to do it by hand and I can see what is going on.  The script doesn't seem to adjust the luminances of the HaGB and HaRGB images for "best fit" as mentioned in the tutorial.  That's the step I haven't been able to figure out myself and I suspect that its absence is why the result is poor, at least for my data.
Anyway, thanks for writing the script, Dave.  I'll keep beating on it for a while and see if I can figure things out.  In the meantime, if anybody can give me some hints as to how to go about the second part of the process (what to do once the HaGB and HaRGB images have been created) then I'd be terribly grateful!
Rick.
