Author Topic: Merge Mosaic Script  (Read 20273 times)
Offline NKV
Re: Merge Mosaic Script
« Reply #15 on: 2010 August 06 03:24:24 »
The resulting Mosaic still seems a little bit dark. Hmmm....
Grorg, I just create Preview, AutoSTF from Preview, transfer STF to HT and HT apply to MainView.
Also, I play with uncalibrated images...
So I think, your script is OK.
Offline ugatza
« Reply #16 on: 2011 August 24 12:26:25 »
Sigo las instrucciones para instalar el módulo gradients merge mosaic, pero no lo hago bien. ¿Alguien podría enseñarme a hacerlo, como si fuera para tontos?
Gracias mil.
I follow the instructions to install the merge module mosaic gradients, but did not do well. Can anyone teach me how to do it, as if to fool?
Thanks a lot.
« Reply #17 on: 2011 August 25 10:41:32 »
This script is now obsolete. Please use the GradientMergeMosaic process described in http://pixinsight.com/forum/index.php?topic=3295.0 and previous threads of similar title. It should be part of your PI installation if you activated the Update-Development repository as described in http://pixinsight.com/forum/index.php?topic=3335.0#new
Offline FunTomas
    • Astrofoto.sk
« Reply #18 on: 2011 October 13 02:19:24 »
I try to merge 3 images. I obtain message Out Of Memory at the begining. Process explorer displays enough free memory at this time. Where is the problem?
PixInsight is running on Win7 at 2GB memory. There wasn't problem with registration of these images due to size.
Offline zvrastil
    • Astrophotography
« Reply #19 on: 2011 October 13 02:25:02 »
Hi Tomáš,
I assume it's 32bit system. I'm not able to merge even two 6MPix frames on 32bit system with 2GB of memory. However, 64bit system (Kubuntu Linux in my case), running on same machine does the merge without problem. I was not able to do the merge on 32bits, regardless of process settings or available memory.
regards, Zbynek
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #20 on: 2011 October 19 03:31:43 »
Hmmm, now there's a thought - set up a dual boot 64bit Linux system so I could process larger mosaics    >:D
Rob's Astropics
« Reply #21 on: 2011 October 19 03:37:28 »
Our approach is slightly different: we only run Linux and FreeBSD on our development machines, and run Windows exclusively on virtual machines (VMware).
« Reply #22 on: 2011 October 27 12:20:34 »
More recent messages on this topic in http://pixinsight.com/forum/index.php?topic=3114.0
