Hey Sander,
Oh, it used up 4 GB of RAM
What's the size of your images (WxHxN and sample type)? SA doesn't hang; it's just very slow because it needs to do a lot of work on disk swap files. If you'd have the patience to wait (it seems eternal at the beginning, but once Windows organizes its swap file the process speeds up), it would complete the task.
That happens because you're using a 64-bit OS. If you were using a 32-bit OS you'd have had a nice "out of memory" error
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
With 4 GB, anything exceeding 2 GB approx. requires disk swapping activity. When you reach the limit of your physical memory, everything becomes extremely slow.
As Niall says, time for an 8 GB upgrade!
