Author Topic: PJSR: How to determine if running on Windows?  (Read 4683 times)
« on: 2010 July 29 12:03:01 »
Is there a simple way to determined from PJSR if PI is running on Windows?
Background: I may need to massage some file names "x/y" to be "x\y", but only when running on Windows. I am giving these file names to an external windows process (via Console.execute()), not to PJSR itself.
Re: PJSR: How to determine if running on Windows?
« Reply #1 on: 2010 July 29 12:18:49 »
Hi Georg,
Use the following preprocessor directive:
#ifeq __PI_PLATFORM__ MSWINDOWS
#endif
The __PI_PLATFORM__ macro is automatically defined for all running PJSR scripts. It can have the following values:
FREEBSD
LINUX
MACOSX
MSWINDOWS
You can check for several platforms in a single directive. For example:
#ifoneof __PI_PLATFORM__ FREEBSD LINUX MACOSX
#endif
or, complementarily:
#ifnoneof __PI_PLATFORM__ FREEBSD LINUX MACOSX
#endif
Good luck with that new script!
« Reply #2 on: 2010 July 29 12:23:27 »
By the way, you can also use the corePlatform property of the Global object:
if ( corePlatform == "MSWINDOWS" )
Although I personally think that dealing with these things at the preprocessor level is more efficient.
You can also use two static methods of the File object:
String File.unixPathToWindows( String path )
String File.windowsPathToUnix( String path )
to accomplish the task that you're trying to do.
