Author Topic: Starting 2nd instance of PI 1.6.1 ....  (Read 3620 times)
Offline Christoph Puetz
    • Fotos
« on: 2010 July 29 08:15:23 »
Hi all,
if I start a second instance of PI 1.6.1 with the command line:
!!$PXI_BINDIR/PixInsight
I get the "New Version" upgrade dialog again.
Is this correct ?
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
Re: Starting 2nd instance of PI 1.6.1 ....
« Reply #1 on: 2010 July 29 21:12:46 »
Yes, for some odd reason each instance of PI gets its own settings. I'm sure Juan has good reasons for it but it's odd enough that I never start a second PI session. I like my settings the way they are :)
    • Fotos
« Reply #2 on: 2010 July 29 23:24:31 »
OK, thanks Sander  :D
Kind regards,
      Christoph
Canon EOS 500d,
« Reply #3 on: 2010 July 31 01:26:46 »
In fact, they way PI handles 'multiple instances' can be extremely useful.
First, if you really want to start a second instance with an 'identical' setup to the first instance, it is a simple case of editting the config file to 'duplicate' the complete section for the 'first instance' and to then rename it as the 'second instance'
Then, once you open the second instance, any configuration changes are saved (on closure of the second instance) in the second section of the configuration file.
What would be EXTREMELY USEFUL is the ability to open a new instance of PI, but to specifically tell PI which configuration profile to use. That way, the user has simplistic 'ultimate' control. In fact, could a running instance of PI be forced to go and 'get' a specific configuration file section? Could you 'save' the running PI configuration into the config file with a specific 'section identifier'?
Juan - your thoughts?
« Reply #4 on: 2010 July 31 02:16:15 »
Hi Niall,
Count on that feature implemented during the 1.6 cycle.
« Reply #5 on: 2010 July 31 03:20:56 »
Thanks Juan - glad to be able to cause you extra trouble ::) ::) ::)
