[Versión en Español al final]Hi everyone,
I am pleased to announce that the new and so long-awaited version 1.6.1 of PixInsight is now available for download from our file servers. Licensed users (both trial and commercial licenses) will find it on the
Software Distribution system, as usual.
I am writing this before sending the standard notification email to all users, and even before writing the required informational/descriptive post on the Release Information forum board. I'll perform both tasks during the incoming hours. I just wanted to let you know that the new version can be downloaded without delaying it more.
Unfortunately, this is not the version that I wanted to release. A number of personal problems, technical difficulties and an extreme workload have made finishing this release much harder than usual, so version 1.6.1 is actually a transitional/bugfix version. The upcoming main improvements to the platform, such as a new XML-based, open-source image format (as the foundation of a project feature), integrated documentation and automatic updates system, will have to wait until the new versions that will be released during Fall-Winter this year.
However, this does not mean that there are no new features, improvements and important changes in version 1.6.1: there are many, and very important, even if some of them are (still) not visible on the surface.
As noted above I'll describe all the new features on a separate post. This is just a brief list of the most important highlights:
- The most stable version of PixInsight ever. I have made huge efforts to achieve the maximum stability in the Core PixInsight application and all standard modules on all supported platforms. Maximizing stability has been the main goal of this version.
First 64-bit version for Mac OS X. PixInsight is now available as a Cocoa-based, 64-bit (x86_64) application on Mac OS X 10.5 (Leopard) and later. Although this version is still
experimental and subject to extensive development, it is fully functional and production stable, and can be used without problems to perform any of the image processing tasks and tools available in PixInsight. There are some issues with the graphical user interface, however, such as wrongly updated and disappearing cursors, erroneous screen updates, and some screen artifacts and flickering problems that prevent us from tagging the current 64-bit Mac OS X version as a "Tier One" release.
- New module installation infrastructure. Backwards compatibility is now ensured for all modules compiled and linked against PCL version 1.0.85 and later. Existing modules require a full rebuild, though, but this is definitely the last time that happens.
- Improved multithreading performance across the whole PixInsight/PCL platform. Redesigned pcl::Mutex class to implement programmable spinning mutexes with virtually zero impact on thread performance under heavy contention.
- Redesigned Process Explorer with seamless integration of featured scripts.
- Improved ImageCalibration tool with selectable additive pedestals (working cooperatively with ImageIntegration) and better automatic dark frame scaling routine.
- New Linear Fit pixel rejection algorithm available on the ImageIntegration tool.
- Improved multiscale noise evaluation in ImageIntegration. The new MRS algorithm implementation is now more accurate and much more robust.
- Improved frame adaptation routine for absolutely seamless mosaic construction with StarAlignment.
- Full set of pixel interpolation algorithms available on StarAlignment, including an automatic mode that selects the optimum interpolation as a function of scale changes.
- New gnomonic projection available on StarGenerator. The new projection improves star matching up to a 30% for generation of mosaics over synthetic star fields.
- Updated set of standard scripts, including the latest revised versions published on PixInsight Forum.
- Hundreds of bug fixes on all platforms.... and more. Thank you all for your support and your patience. I hope the long wait will be worth it. Enjoy!
Hola a todos,
Me complace anunciar que la nueva y tan esperada versión 1.6.1 de PixInsight ya está disponible para su descarga desde nuestros servidores de archivos. Los usuarios con licencia (tanto de pruebas como comerciales) la encontrarán en nuestro sistema de distribución de archivos, como de costumbre.
Estoy escribiendo esto antes de enviar la notificación por correo electrónico estándar para todos los usuarios, e incluso antes de escribir la información sobre las nuevas características y mejoras en el foro de información sobre versiones. Voy a realizar ambas tareas durante las horas siguientes. Sólo quería haceros saber que la nueva versión se puede descargar sin que se retrase más.
Desafortunadamente, esta no es la versión que yo quería publicar. Una serie de problemas personales, dificultades técnicas y una carga de trabajo extrema han hecho que esta versión sea mucho más difícil de lo habitual, por lo que la versión 1.6.1 es en realidad una versión de transición y corrección de errores. Las mejoras principales en la plataforma, tales como un nuevo formato de archivo de código abierto basado en XML, (como base para la nueva funcionalidad de proyectos), la documentación integrada y un sistema de actualizaciones automáticas, tendrán que esperar hasta las nuevas versiones que se publicarán durante el otoño-invierno de este año.
Sin embargo, esto no significa que no haya nuevas características, mejoras y cambios importantes en la versión 1.6.1: hay muchos, y muy importantes, aunque algunos de ellos no son (todavía) visibles en la superficie.
Como señalaba anteriormente voy a describir todas las nuevas características en un post aparte. Esto es sólo una breve lista de los cambios y mejoras más importantes:
- La versión más estable de PixInsight jamás publicada. He realizado grandes esfuerzos para lograr la máxima estabilidad en la aplicación PixInsight Core y en todos los módulos estándar para todas las plataformas soportadas. Maximizar la estabilidad ha sido el objetivo principal de esta versión.
- La primera versión de 64 bits para Mac OS X. PixInsight está ahora disponible como una aplicación basada en Cocoa de 64 bits (x86_64) para Mac OS X 10.6 (Snow Leopard) y posterior. Aunque esta versión es aún
experimental y sujeta a un profundo trabajo de desarrollo, es totalmente funcional y estable, y se puede utilizar sin problemas para realizar cualquiera de las tareas de procesamiento de imágenes y herramientas disponibles en PixInsight. Hay algunos problemas con la interfaz gráfica de usuario, sin embargo, como cursores que no se actualizan bien y que a veces desaparecen, actualizaciones erróneas de pantalla, y algunos artefactos y problemas de parpadeo en el dibujo en pantalla, que impiden calificar a esta versión de 64 bits para Mac OS X como una versión de primer nivel.
- Nueva infraestructura de instalación de módulos. Ahora la compatibilidad con versiones anteriores está garantizada para todos los módulos compilados y enlazados con la versión 1.0.85 de PCL y posteriores. Los módulos existentes requieren una reconstrucción completa, pero esta es definitivamente la última vez que esto sucede.
- Mejora en el rendimiento multitarea para el conjunto de la plataforma PixInsight / PCL.
- Process Explorer rediseñado con integración perfecta de los scripts seleccionados.
- Mejoras en la herramienta ImageCalibration con pedestales aditivos definibles por el usuario, que trabajan en cooperación con ImageIntegration, y rutinas de escalado automático de darks mejoradas.
- Nuevo algoritmo Linear Fit Clipping de rechazo de píxeles disponible en la herramienta ImageIntegration.
- Mejora de la rutina de evaluación de ruido multiescala (MRS) en ImageIntegration. El algoritmo MRS en su nueva implementación es ahora más preciso y mucho más robusto.
- Mejora en la función de adaptación de teselas para la construcción de mosaicos sin costuras con StarAlignment.
- Conjunto completo de algoritmos de interpolación de píxeles disponible en StarAlignment, incluyendo un modo automático que selecciona la interpolación óptima en función de los cambios de escala producidos durante el registro.
- Nueva proyección gnomónica disponible en StarGenerator. La nueva proyección mejora el emparejamiento de estrellas hasta un 30% en la generación de mosaicos sobre campos de estrellas sintéticos.
- Conjunto de scripts estándar actualizado, incluyendo las últimas versiones revisadas de los scripts publicados en PixInsight Forum.
- Cientos de correcciones de errores en todas las plataformas.
... y mucho más. Gracias a todos por vuestro apoyo y vuestra paciencia. Espero que la larga espera valdrá la pena. A disfrutar!
