Author Topic: NGC7000 wide field without telescope  (Read 3155 times)
« on: 2010 July 18 09:40:57 »
It was one of those nights after a more thas long day in the office that I could not muster the energy to set up my telescope. But sky was clear, new moon, so why not try something quick. So I set up my camera in my roof top window and just let it shoot the sky above.
Therefore, the attached picture is notable because of the equipment that was not used to create it:
- no telescope (just a 85 mm lens)
- no astro CCD camera (just a plain Canon EOS40D without modification)
- no mount (just the edge of my roof top window)
- no tracking, no guiding (just 380 second shots of 10 seconds each)
Pictures were calibrated with Deep Sky Stacker, aligned and integrated with PI. General procedure:
- use DSS to calibrate with bias, flats, darks (using the intermediate files option)
- create master registration frame from shots 1, 150, 300 using Star Alignment-Register Mosaic-Union. Using only one of the frames for registration leads to notable lens distortions in the regions were the master registration frame is just black. Basically, this is the reason why I did registration with PI this time: DSS would not allow me to provide a master registration frame.
- use PI to align & integrate. Currently I am limited to integrating 300 pictures due to a restriction in version 1.60 (see http://pixinsight.com/forum/index.php?topic=2053.msg13262#msg13262)
- Dynamic Crop
- Dynamic Background Extraction (what a fantastic tool)
- Histogram Transform
- Color Saturation boost (to better show the H-alpha regions)
I am truly amazed to see what could be done with equipment that almost any serious photographer somewhere has in his/her desk.
Enjoy,
PS: The picture still has a couple of artifacts that I hope to remove in a second run. I plan to do it when PI 1.61 becomes availble (i.e. next week on the relativistic time scale  ;) ).
« Last Edit: 2010 July 18 11:42:39 by georg.viehoever »
Re: NGC7000 wide field without telescope
« Reply #1 on: 2010 July 19 08:29:28 »
Very cool Georg! Well done.
Offline tnkumar
« Reply #2 on: 2012 February 29 06:31:02 »
Why did you choose DSS and not choose Pixinsight for calibration?
« Reply #3 on: 2012 February 29 06:32:16 »
I was too lazy. DSS is a one button solution, PI needs much more work (but often also gives better results).
« Reply #4 on: 2012 February 29 06:37:11 »
I do all my calibration and stacking with my own tool (fixfits) and DSS. I use PI's image integration and registration capabilities for other purposes such as when I simply need some frames averaged or when two images of arbitrary scales need to be registered.
It's good to have a full toolbox.
