Author Topic: Fit 32 file format issue?  (Read 3736 times)
Offline lucchett
« on: 2010 July 16 12:15:26 »
Hi, I've aligned some 32 bit fits calibrated in maxim in PI.
the aligned file open as empty in PI (k=0).
I.ve checked back in maxim and the integration module did detected stars and aligned the stars (the images are correct).
I'cve then checked back and find out that the original 32 bit files used to align, open also as empty in PI.
Hope this helps,
Andrea
Re: Fit 32 file format issue?
« Reply #1 on: 2010 July 16 12:24:00 »
I don't think Juan can do much with this trouble report without a file to download and try for himself. Can you reproduce this with a small (cropped) file that's easy to attach here?
Offline lucchett
« Reply #2 on: 2010 July 16 13:03:15 »
Hi Sander,
ca you explain how to attach a file to the post?
I thought I could send the original file to an ftp, but I was waiting for directions.
Many thanks,
Andrea
« Reply #3 on: 2010 July 16 13:08:23 »
Sure, when you post, click on 'additional options'.
Offline lucchett
« Reply #4 on: 2010 July 16 13:37:24 »
this is a crop.
this open in maxim and it doesn't in PI (it opens empty).
I've tried to write the aligned file also in 32bit float: in this case maxim is still able to open it, put the reading value is zero all over the frame.(this is outside my comprehension..)
Andrea
Offline lucchett
« Reply #5 on: 2010 July 16 13:43:35 »
this is a crop.
Andrea
last piece: if after alignment the resulting files are converted in IEEE float in Maxim then they open correctly in PI.
Andrea
