Author Topic: How to combine a L with RGB  (Read 3520 times)
Offline Emanuele
« on: 2010 July 15 05:13:22 »
Hi all.
Stupid question here but I really have tried everything.
I have extracted the Luminance channel from an RGB image taken from the web.  Now I worked on the L, enhancing it a bit, and I want to recombine the image, using the new L as Luminance and the original image as RGB (for color only)
How can I do it in PI? I know how to do it in Photoshop....
If i use LRGBCombination it tells me that it cannot work on Greyscale images.
Thanks.
E.
Offline Jack Harvey
Re: How to combine a L with RGB
« Reply #1 on: 2010 July 15 05:58:55 »
Open the Channel Combine tool, select the L,a,b button, uncheck a and b and put your new Lum in the L space.  Drag the triangle onto the image in which you wish to insert your new Lum.
Jack Harvey, PTeam Member
Offline Emanuele
« Reply #2 on: 2010 July 15 06:46:53 »
easy peasy!! ;)
Thank you Jack!
« Reply #3 on: 2010 July 16 10:22:44 »
Also keep in mind that most processes can operate on just L so there may not be a need at all to extract, process and re-apply it. You can choose to display just the L component of a color image.
Offline Jack Harvey
« Reply #4 on: 2010 July 16 11:11:43 »
Good Point Sander
