Author Topic: how to use preview replace script  (Read 4316 times)
Offline gvanhau
« on: 2010 July 14 12:14:51 »
Hello
I've been using PI1.6 for a couple of moths.
I'm still in the learnign curve.
Yesterday I found the replace preview scrip, buy I never got the results I espected: replace the contents of a preview area of one image with the contens of another image or preview.
Can some one explain to me how it works?
I normaly use TIFF images.
Regards
Geert
Geert Vanhauwaert
Offline Silvercup
Re: how to use preview replace script
« Reply #1 on: 2010 July 14 12:37:33 »
Hi:
It just copy a preview or several previews of an image into another one in the same position.
Best. Silvercup.
Offline gvanhau
« Reply #2 on: 2010 July 14 13:25:54 »
Hello Silvercup
I tried to do this, but the preview was never copied on to the target image.
Can you tell me if there is a pre requisite for doing this? can it be don with color images?
Could there be a bug in the script?
I use 64 bit windows 7.
regards
Geert
Geert Vanhauwaert
« Reply #3 on: 2010 July 14 13:37:10 »
Hmm, I don't even see it list previews in the selection boxes.
Offline gvanhau
« Reply #4 on: 2010 July 19 08:11:36 »
Ok, I´m already discovered how it works:
Target image mus be same size as source image.
You work on a preview area in source image, then replace the area of the preview in the target image.
It could be interesting if there was no restriction of size.
Regards
Geert
Geert Vanhauwaert
