Author Topic: Need Help on Processing Comet  (Read 27929 times)
Offline twade
Re: Need Help on Processing Comet
« Reply #30 on: 2010 July 01 21:02:58 »
To all,
After a couple of iterations of DBE using lots of sample points on each channel, several iterations of SCNR to remove a red cast, and a curves transform using the red channel to remove too much red in the tail, I finally have a decent color image to blend with the luminance data.  I also painted most of the remaining stars out of the image.  Here are the imaging details:
Camera:  FLI PL-16803
Lens: Pentax 67 300mm f/4.0 EDIF (used wide-open)
Data:
Red (3x3): 5 - 90s
Green (3x3): 5 - 105s
Blue (3x3): 5 - 135s
I'm hoping to add the luminance data either later tonight or Friday, depending on how much effort it takes to remove the gradients in the luminance channel.  I also plan to do some noise reduction.
Wade
Offline twade
« Reply #31 on: 2010 July 01 23:07:03 »
To all,
I believe it's ready for the star-field.  I have added the luminance data.  It's still a little noisy, but given what I had to work with I believe it turned out quite nicely.  I appreciate all your help.  Here's the final image details:
Data:
Luminance (1x1): 180s
Red (3x3): 5 - 90s
Calibration was done in Maxim DL.  All other processing was in PixInsight.
I plan on taking the background star-field in August when this area is higher in the sky.  Hopefully, it will be clear and smoke free.
Wade
Offline mmirot
« Reply #32 on: 2010 July 02 06:41:24 »
Well done Wade.
Tricky processing. I have 6 x 45 seconds image in RGB only for this object. I am not sure the S/N will be worth it but I will give this a try.
Max
Offline RBA
    • DeepSkyColors
« Reply #33 on: 2011 October 03 14:57:23 »
Hi Wade,
Thank you for uploading the images. Here is my solution to this nice image processing problem.
Juan, where did the screen-shots that came with your post go??
« Reply #34 on: 2011 October 04 02:11:10 »
Hi Rogelio,
Thanks for pointing this out. These files were in the wrong directory after some restructuring of our server. They are back in place now.
Unfortunately these aren't the only forum images that are now inaccessible. I'll try to fix all missing images; if you see other threads where this happens, please let me know.
Offline FunTomas
    • Astrofoto.sk
« Reply #35 on: 2013 January 14 00:06:11 »
Hi boys. I cannot reproduce Juan's tutorial. Images of comet and comet+stars are so different, that after substraction I got near black image. Could someone help me with this problem? I uploaded set of images to http://endor.uv.es//data/public/5972fad22f61f26123a53a9501f2c6e5.php?lang=en
Many thanks for any suggest.
Offline astroedo
  • Io ne ho viste... cose che voi umani...
    • L'arciere celeste
« Reply #36 on: 2015 January 05 10:05:42 »
Hi! I have the same problem because the background in Full and Comet images is the same so many pixels are clipped to 0 when I perform
Full-Comet operation to get the stars image.
I've solved changing Juan expressions as follows
for the stars image:
Full-Comet+med(Comet) this is the new stars image
Star removal from full image
x = k*med( stars );
$T - iif( stars > x, stars, stars*(1 - (x - stars)/x) )+med( stars)
I really don't know if it is the right solution, but it works!
bye Edoardo
Offline FunTomas
    • Astrofoto.sk
« Reply #37 on: 2015 January 05 10:16:55 »
Thank You Edoardo. I try your suggestion as soon as possible. Maybe with data of the comet Lovejoy taken this night.
Offline astroedo
    • L'arciere celeste
« Reply #38 on: 2015 January 05 10:23:16 »
I'm trying right now with the same comet  ;D :laugh: :cheesy:
Offline cdavid
    • Through Space and Time
« Reply #39 on: 2015 January 23 06:22:22 »
Hi everyone, I also am trying this pixel math process on Lovejoy and I'm getting nothing but black.  When I add back the +med(stars) variable I end up with a bizarre "negative" like image of some of the comet.
Any ideas?
Carlos
Offline NKV
« Reply #40 on: 2015 January 31 06:26:54 »
x = k*med( stars );
my solution:
x, k=1.1, m
x=k*m; m=med(stars); $T - iif( stars > x, (stars-m), (stars-m)*(1-(x-stars)/x) )
