Author Topic: New APOD?  (Read 8064 times)
Offline Ginge
New APOD?
« on: 2010 June 11 04:02:29 »
I see you are credited on todays APOD, Jack and Juan. Congrats! It's a magnificent image!
Best regards,
Ginge
Re: New APOD?
« Reply #1 on: 2010 June 11 06:39:06 »
Hey! Congrats Vicent :) You made it ;)
Offline RBA
    • DeepSkyColors
Re: New APOD?
« Reply #2 on: 2010 June 11 08:44:51 »
Why the question mark in the suject? It is a new APOD, or is it not? ;)
The image:
Aggressive, powerful, high contrasts, aesthetically it is clear that is not to please everyone, captured with equipment not within the reach of most people for these purposes, processed following well known guidelines and applying a style equally well known. A credit line maybe a bit long and confusing.
All photos signed by the DSA show a very similar style. It would be interesting to see images that use the same principles but with different interpretations, IMHO. The reason for saying this is because as I understand it, the DSA is based on certain principles, not a particular style, and if all DSA-signed images present a similar style it may lead to confusion about what the DSA stands for. Just my opinion, it's your party so run it as you wish. I also see Juan in the credits, I thought he only writes code  >:D
What attracts me the most is the emphasis in the Ha areas on top of NGC 5195, and I think that's what sets this image apart from others of the same object. On the other hand, what intrigues me is the strong Ha halo around M51, and I'd be interested in learning more about that, as apparently the ha image doesn't seem to present a significant signal increase in those areas.
Congratulations to the team! It is a new view of M51, and quite a  treat.
Offline vicent_peris
    • http://www.astrofoto.es/
Re: New APOD?
« Reply #3 on: 2010 June 11 09:31:31 »
Hi all, thanks you very much,
Hi Rogelio,
we cannot publish the images without giving credit to all the institutions involved in this project. DSA is working with Descubre Foundation to make this photographic work. Descubre buys time observing time at the CAHA's 1.23m scope for us. On the other hand, I work at the OAUV and I spend a large portion of my day working on this project, so OAUV must be also credited.
As responsible of the DSA work at CAHA, I act as "director" of the image processing. Each involved member works in the image, and then I put all together the best part of each result in the final image. As we usually are always the same people, our works tend to have similar aesthetics. :-D
For other works inside the DSA, see SSRO website. They have a different style IMO.
He did a very nice work at the noise reduction steps.
There's no special emphasis on these areas. All the H-alpha frame was blended and processed with the R channel in the same way. In fact, the HII areas inside NGC5194 are so much red because to really show the NGC5195 arc we must to multiply the H-alpha channel by 4.
See this image with more aggresive histogram adjustment and curves:
The hallo really exists, is not an artifact or a gradient.
Best regards,
Vicent.
[/quote]
Re: New APOD?
« Reply #4 on: 2010 June 11 10:07:13 »
Only the 99.99999999% of my working time. In the other 9.999993721976352x10-9% (using IEEE arithmetics here) I sometimes do some image processing, just for fun. O:)  ;D
Offline Harry page
Re: New APOD?
« Reply #5 on: 2010 June 11 12:47:43 »
More well dones and congrats from me  :D
I still want to know how you did it  :P
Harry
Harry Page
Offline RobF2
  • Rob
    • Rob's Astropics
Re: New APOD?
« Reply #6 on: 2010 June 11 17:27:29 »
Stunning pic
Here's the link for lazies like my that were looking for one above:   http://apod.nasa.gov/apod/ap100611.html
Is anyone aware of any modelling having been done on the interaction of these 2?  It almost looks like a collision where the top galaxy has sheard 25% off the side of the larger galaxy?
Rob's Astropics
