Author Topic: Best way RGB debayer  (Read 9225 times)
Offline Silvercup
« on: 2010 June 11 03:18:11 »
Hi All:
How could I debayer a raw image with R-G-B bayer matrix?
I don't know RGB weights.
Thanks. Silvercup
Re: Best way RGB debayer
« Reply #1 on: 2010 June 11 03:36:59 »
Just deBayer it with 1:1:1 weights to begin with.
Then rely on BackgroundNeutralisation and ColourCorrection to sort things out for you.
If you want to get 'more accurate', I posted (somewhere on the Forum) a FITS 'colour chart' that you can print out and image - in daylight - using the CCD that you are working with. Then you can 'tweak' a deBayer process using that, adjusting the colour balance array until you feel happy with the results.
(answered in haste)
« Reply #2 on: 2010 June 11 03:45:42 »
Silvercup,
I just did a quick search, so you might want to have a look at
http://pixinsight.com/forum/index.php?topic=1628.0
However, the links on that page are broken. You will need to use
BMP   (900Kb) http://74.50.19.20/nsaunders/NewSimpleTestCard.bmp
FITS (3.51Mb) http://74.50.19.20/nsaunders/NewSimpleTestCard.fts
The test card looks like this:-
Offline Silvercup
« Reply #3 on: 2010 June 13 15:38:57 »
Hi Niall:
Thanks for your help.
I want to process Mars Express webcam images. Mars Express images are RGB-RGB-RGB bayer patern. There is an aplication to debayer raw images but I want to do with Pixi, I think it can do better. So I can use Process container to process entire set of images.
This is raw image decoded with pixi:
This is a reprocess of a mosaic done by Roman Makhin:
Original work are here:
http://webservices.esa.int/blog/post/6/1010
Raw images are on http://webservices.esa.int/blog/blog/6
Any help appreciated. Silvercup.
« Reply #4 on: 2010 June 14 06:14:47 »
Hi Silvercup,
OK - I have just spent an hour quickly acquainting myself with the Mars Express VMC Forum (http://www.unmannedspaceflight.com/index.php?showtopic=5415) and my initial feeleing is that their basic RAW images should be capable of being deBayered here on PI - using any of the deBayer routines that have been produced (other than 'my' one, which will not work for RGBG or RGGB CFAs).
Nowhere on their Forum did I read about WHAT the exact CFA layout is - so I can't help there. Why nobody has described it I don't know. The guy who wrote the VMC2RGB routine is an obvious starting point. I believe that he may have written this in Java (?) so it might be an easy step for him to create a PJSR equivalent.
Looking quickly at what they are trying to achieve on that site, it becomes screamingly obvious that PixInsight would be a better option for a lot of the processing that they are trying to do.
If I get some spare time, I'll maybe try my hand at one of their RAW images, processing entirely in PI.
