I loaded FITS color images (RGB, int8) into the Aladin application. Aladin considers these to be a "data-cube" and displays it as a time sequence, automatically sequencing through the 3 channels. It is possible to create RGB images in Aladin, and this is what I did with separate R,G,B images created from PI. I then saved the result as a FITS. Both PI and Aladin reload the created file as a true color image. As far as I could see the only significant difference in the FITS header was that PI sets "extend=T", whereas this keyworld is missing in the version created by Aladin.
I dont know if this is an area where FITS is not well defined. But I would certainly prefer to be able to use PI FITS color images in Aladin without tricks. Would it be possible to remove the "extend=3" keyword by default?
