Author Topic: Need Images with gradients  (Read 5784 times)
Offline Silvercup
« on: 2010 May 16 12:30:18 »
Hi All:
Has anyone an image with gradients not corrected with DBE like this??
I'm working with a Background correction procedure when DBE fails and need some images as examples to work with it.
Thanks. Silvercup
Offline bitli
Re: Need Images with gradients
« Reply #1 on: 2010 May 17 12:23:35 »
If you are really courageous I can send you the tiff of the following one (from a Canon in raw),
all I was able to do in a grey scale of the galaxy...
-- bitli
Offline Silvercup
« Reply #2 on: 2010 May 18 08:16:56 »
Hi Bilti:
This is a preliminary result of the procedure.
Saturared:
Normal:
Lack of signal due to vigneting is irreparable. Rest of gradients IMHO are properly corrected.
Need feedback.
Best. Silvercup.
« Reply #3 on: 2010 May 18 09:01:03 »
I don't see any images?
« Reply #4 on: 2010 May 18 09:12:56 »
Hi Sander - they are appearing OK on my PC ???
« Reply #5 on: 2010 May 18 09:21:22 »
Ah, they're there now :)
« Reply #6 on: 2010 May 18 09:58:40 »
Bitli,
This does not look like light pollution to me, rather bad flats and some other light source. For my Canon EOS40D, it was necessary to cover the view finder with black cloth, otherwise light entering this way would pollute my images.
Offline bitli
« Reply #7 on: 2010 May 18 11:40:25 »
Silvercup
Yes it is a pretty good result, you are able to recover a larger part of the image than I was able to. It is quite fantastic what one can recover with PI.
Georg,
Thanks for the tip on the view finder, this may have impacted some of my images. I will try next time. In this case I had indeed problems with the flat (to say the least). The light I used to aim at a reflector pannel broke (understandably so, as I let it fall on the floor), and I improvised a flat with an old napkin and a torch light. With limited success, as you see.
-- bitli
« Reply #8 on: 2010 May 18 12:17:50 »
Hu bitli
Have you tried the white t-shirt method? :D
I do something very similar to get flats with canon lens.
