Author Topic: Blinking Script  (Read 111403 times)
Re: Blinking Script
« Reply #135 on: 2010 September 01 10:51:12 »
function EvolutionEngine()
   this.inputFiles = new Array;
   this.bitsPerSample = 8;
   this.floatSample = false;
   this.xev = 0;
   this.yev = 0;
   this.processFiles = function()
      var fileName = 'analysis';
      fileName = File.appendToName( fileName, '_x' );
      fileName = File.appendToName( fileName, Number.toString(this.xev));
      fileName = File.appendToName( fileName, 'y');
      fileName = File.appendToName( fileName, Number.toString(this.yev) );
      //fileName = File.appendToName( fileName, '_x'+Number.toString(this.xev)+'y'+Number.toString(this.yev) );
      var filenamePlot = File.appendToName( fileName, '_plot' );
      var filenameEvo = File.appendToName( fileName, '_evolution' );
      var wPlot = new ImageWindow(this.inputFiles.length, 1001, 1,8, false, false, 'plot');
      var wEvo = new ImageWindow(this.inputFiles.length, 1, 1, 32, true, false, 'pixelEvolution');
      var vPlot = wPlot.mainView;
      vPlot.beginProcess (UndoFlag_NoSwapFile);
      vPlot.image.apply(1);
      var vEvo = wEvo.mainView;
      vEvo.beginProcess (UndoFlag_NoSwapFile);
      for ( var i = 0; i < this.inputFiles.length; ++i )
         var w = ImageWindow.open( this.inputFiles[i] );
         if ( w.length == 0 && i+1 < this.inputFiles.length )
            var msg = new MessageBox( "<p>Unable to load input image file:</p>" +
                                      "<p>" + this.inputFiles[i] + "</p>" +
                                      "<p><b>Continue pixel evolution analysis ?</b></p>",
                                      TITLE, StdIcon_Error, StdButton_Yes, StdButton_No );
            if ( msg.execute() == StdButton_No )
               break;
         for ( var j = 0; j < w.length; ++j )
            var view = w[j].mainView;
            view.beginProcess (UndoFlag_NoSwapFile);
            var f = view.image.sample(this.xev,this.yev,0);
            vEvo.image.setSample( f,i,0);
            var p = 1000-Math.round(1000*f);
            for ( var k = p; k <= 1000; ++k )
              vPlot.image.setSample( 0,i,k);
            view.endProcess();
            w[j].forceClose();
      vPlot.endProcess();
      vEvo.endProcess();
      wPlot.show();
      wEvo.show();
var engine = new EvolutionEngine;
As promised... hope this helps (and you takes the ball ;) )
Offline NKV
Re: Blinking Script
« Reply #136 on: 2010 September 01 23:57:03 »
Thanks Carlos.
One question: Why you use:
for ( var j = 0; j < w.length; ++j )I not understand in which situation w.length > 1 ?
Any way... ver 2.9
+evolution analysis
PS there are error. so, don't try to use it on single image. fixed
« Last Edit: 2010 September 02 21:28:02 by NKV »
Re: Blinking Script
« Reply #137 on: 2010 September 02 04:24:23 »
To be honest, I didn't understand that either :D I just used the batch format script as base, and if Juan wrote that, it should have been for a good reason :D  Anyway, that works :P
Re: Blinking Script
« Reply #138 on: 2010 September 02 12:42:39 »
Just tried the new feature :) really fast, and works pretty well. Congrats ;)
Offline NKV
Re: Blinking Script
« Reply #139 on: 2010 September 02 21:46:31 »
Thanks Carlos.
I updated the script above (fixed zero-division problem).
Note, i add auto min/max rejection. So the graph show only distribution between mim/max values in sequence of images.
Also, because the script operate at images in memory, impossible to analyze QTY of images, so independent version of EvolutionEngine is good idea.
Re: Blinking Script
« Reply #140 on: 2010 September 03 06:26:09 »
In fact, this was exactly the same motive why I wanted that to be in your script ;) Mine loaded the images at requests, and this may get pretty boring if you want to inspect several points.
Offline mmirot
Re: Blinking Script
« Reply #141 on: 2010 September 16 21:19:45 »
I get a syntax error on line #1 on all the latest version of this script.
Max
Offline NKV
Re: Blinking Script
« Reply #142 on: 2010 September 16 21:48:26 »
Max
Max, please show me report from Processing Console or Print Screen with the error.
Re: Blinking Script
« Reply #143 on: 2010 September 17 08:46:16 »
Code:
I figured out that cicle. It is there in the case of stored arrays of images. I think that FITS and TIFF support multiple images to be stored in a single file.
Offline mmirot
Re: Blinking Script
« Reply #144 on: 2010 September 17 17:25:40 »
Max
Nevermind,
The script is ok. Fantastic work in fact.
Another kind of problem with my last install was messing it up.
Max
Offline mmirot
Re: Blinking Script
« Reply #145 on: 2010 September 26 20:11:49 »
When I try " save selected" it only saves a single image.
( I made a new directory first)
I assume it was intended to save all checked images.
Max
Offline NKV
Re: Blinking Script
« Reply #146 on: 2010 September 26 20:20:36 »
I think you select only one file.
Note: Selected and checked is different. ;) Try again or show me PrintScreen.
Re: Blinking Script
« Reply #147 on: 2010 September 26 20:32:19 »
Don't know if this has been implemented yet... Is there a way to blink using one reference frame (fixed) between the others?
Offline NKV
Re: Blinking Script
« Reply #148 on: 2010 September 26 22:37:29 »
Double click at reference frame.
Re: Blinking Script
« Reply #149 on: 2010 September 27 06:46:13 »
:P Ok! ;)
