Author Topic: Blinking Script  (Read 111676 times)
Re: Blinking Script
« Reply #105 on: 2010 July 14 17:02:27 »
Where is the last version of this script?
Max
Hi Max,
Have a look at reply #101
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Re: Blinking Script
« Reply #106 on: 2010 July 30 10:11:16 »
I really like this script. I have a question: there is a way to see the images in their original aspect? (when open the image set automatically applies a similar -or equal- to STF, and sometimes I would like to examine them unchanged)
Thanks for this great job!,
Best regards,
Enzo.
Offline NKV
Re: Blinking Script
« Reply #107 on: 2010 July 30 10:17:55 »
Best regards,
Enzo.
OK, I can add button for you. Anything else?
    • Astronomí­a Sur
Re: Blinking Script
« Reply #108 on: 2010 July 30 10:29:18 »
You're fast :D
Just that. Thank you very much!
Re: Blinking Script
« Reply #109 on: 2010 July 31 00:58:42 »
Hi Nikolay,
I think it might be useful if you could post a 'new link' to the latest version of the script.
Keep up the good work.
Offline NKV
Re: Blinking Script
« Reply #110 on: 2010 August 05 00:22:45 »
Hello guys. New version 2.2.
+ new button: Reset STF and Histogram.
« Last Edit: 2010 August 05 03:36:59 by NKV »
Re: Blinking Script
« Reply #111 on: 2010 August 05 02:51:38 »
Thanks Nikolay,
Once again, I will have a look at it once I get back to my 'main machine' tonight.
Offline NKV
Re: Blinking Script
« Reply #112 on: 2010 August 05 03:36:29 »
beer ... Who promised a beer?
Ver 2.3
+ Simple dark subtraction :)
« Last Edit: 2010 August 06 01:28:41 by NKV »
Re: Blinking Script
« Reply #113 on: 2010 August 05 06:07:59 »
An animation script requires a special beer delivery. Enjoy (responsibly ::))
    • Astronomí­a Sur
Re: Blinking Script
« Reply #114 on: 2010 August 05 08:23:36 »
Thanks Nikolay! Splendid work! I tried it and it worked perfectly. Great!  :D
Enzo.
Offline Harry page
Re: Blinking Script
« Reply #115 on: 2010 August 05 10:22:52 »
Excellent work again  :D
Now for people like me who do not use darks , I am sure you could make this script divide a flat and apply a bias calibration done would be great inspect all images , do a simple calibration and save them to file, ;D
Yes I know more beer required :moneyinmouth:
Harry
Harry Page
Offline NKV
Re: Blinking Script
« Reply #116 on: 2010 August 05 20:21:58 »
Hi, Harry.
Yes. I will. But note: in your case dark=bias.
Also, I think about fast (real time) switch between calibrated / not calibrated view. But it's required twice volume  of memory...
Now, if you choose dark1, then dark2,... and again choose dark1, you will every time wait until the script recalculate all Light.
Current method don't requite additional RAM(and I use Redo/Undo to fastest method of reopen original Light), but impossible real-time switching between two dark :sad:
So, if we prefer to see real-time results compare of applying different bias+dark+flat+flatdark it's require huge of RAM.
Also, what about the bit depth of files after the calibration? Now, the bit depth before = after calibration. I prefer minimum to increase it twice... requite additional RAM if we like to see "real" result of calibration. I say "real" (not real-time), because I can add to the script one trick: I can decrease bit depth of Light (file in memory) to screen resolution. In that way 1) we must forgot about STF and use only "slow" HistogramTransformation. I mean "slow", because STF need to apply to one frame, HT need to apply to every Light. 2) Statistics require original files (without HT and in full bit depth), so will work from HDD - it's will slow.
So I don't sure about usability of the script... :-\
Thanks. No need more, Niall brought enough beer.
Offline NKV
Re: Blinking Script
« Reply #117 on: 2010 August 06 01:38:21 »
Ver 2.4
+Reset master dark button.
Ver 2.5
+Show Calibrated button (real-time switch), so current version required double amount of RAM. Push me if I go by wrong way.
« Last Edit: 2010 August 06 02:06:26 by NKV »
    • Astronomí­a Sur
Re: Blinking Script
« Reply #118 on: 2010 August 06 09:43:53 »
Great work Nikolay! Thanks!
A minor detail: using the MasterDark and reseting it, when you close the script the postfix "_c" images remains open (hidden)
Best regards,
Enzo.
Offline Harry page
Re: Blinking Script
« Reply #119 on: 2010 August 06 10:42:39 »
I am sure a man of your kaliver can manage to do it  :D
If beer won't do it , are we talking vodka  ;D
Harry
Harry Page
