Author Topic: how would you go about processing a huge neb field?  (Read 8729 times)
Offline h0ughy
last night i managed to get over 4.5 hours of imaging done on Eta Carina.  i know that when i finally finish stacking the shots and start to process that my field will be full of nebulousity.  How do i go about doing DBE etc and processing the image?  the other shots i have done have done hav been M83 and Omega Centauri and i have had background stars that i could colourbalance with?  I have included a small version of one of the frames that i am currently stacking (87 x 3minutes)
Doghouse Observatory
Re: how would you go about processing a huge neb field?
« Reply #1 on: 2010 May 05 18:07:03 »
DBE: You (almost) can't :D Try to find some very dark dust lines, and make use of symmetries (if possible)  to cover the image. Use that procedure only for mild radial gradients, or almost linear ones. A good flat is irreplaceable.
Color balance: I use those dust lines too, but most times I don't perform any color balance based of the image information, since I already know the multiplication factors that apply to my canon sensor. Just set the black and white points as usual, and everything should go smooth :D
Offline h0ughy
« Reply #2 on: 2010 May 05 20:00:55 »
apart  from a night tinkering and not knowing what to set with the black point and the white point.  i did take good flats - just that wont remove lightpollution.
thanks for the ideas though
« Reply #3 on: 2010 May 05 20:31:47 »
Light pollution typically is a linear gradient. Try to determine the direction and then you may put some "fixed value" samples over the image to fix it. As I said before, use some dark dust patches as reference.
I set the black & white points using a statistical approach (automatic set). For the black point, 0.01%, and 0.002% for the white point. Then, just check the black points at each channel, so neither of them goes beyond the uprising curve, or has been left on the pure black.
Offline Silvercup
« Reply #4 on: 2010 May 06 03:29:48 »
Hi:
I think ABE woul'd do a good job. How about clasic PM expresion $T-med($T) for background calibration?
Color calibration is just another history.
Best Silvercup
« Reply #5 on: 2010 May 06 06:20:23 »
Hi Silvercup
No, ABE will fail in this case, as your expression. Red will dominate, and this is fine. You just have to rely on your calibration frames, and use the dust lines to get rid of the light pollution (with DBE). For color balance, you may set the black point using the dust lines (since they are the darker features) and try to perform a balance based on the stars (like G2V or other better method).
Offline Harry page
« Reply #6 on: 2010 May 06 11:27:49 »
You can get away with very few samples
Have a look here http://www.harrysastroshed.com/pixuser/DBEpart2.html
Harry
Harry Page
Offline h0ughy
« Reply #7 on: 2010 May 06 14:23:46 »
Harry
thanks Harry
« Reply #8 on: 2010 May 11 21:09:05 »
DBE without background patches is hard. Dark dust lanes aren't even the same as background as they're darker than the background. I sometimes create a registered Deep Sky Survey image that I use to find the dimmest areas of the nebula and use those for DBE samples. Still that won't work if there's no background.
For large fields of view I've found that gradients can be quite complex in the final image, especially for long duration exposures with perhaps a meridian flip thrown in. After all the gradient varies as you track the sky. At least in my case the LP is brighter as you get closer to the horizon.
To be fair though your image doesn't seem to have heavy gradients. Perhaps just color calibration can take care of it?
Offline h0ughy
« Reply #9 on: 2010 May 11 22:17:26 »
so how would you colour calibrate that image?
« Reply #10 on: 2010 May 12 06:55:58 »
Ha, that's a good question :)
Clearly the stars are available as an average white reference but what to use as a background reference? If there's a small patch of dark I'd use that. I don't know what to do if there's not a single patch of dark. Someone else will have to suggest a better method than 'fiddle with the histogram till it looks nice'.
« Reply #11 on: 2010 May 12 07:57:26 »
One method is to calibrate your filters (or bayer matrix) with another image. Find the right multiplicative factors that calibrates the image when it is linear. After that, all you have to do is apply the same stretching parameters to all of the channels. With this procedure, only minor touches are needed with curves, to get a more pleasant color, but you'll be close enough to the "real" ones.
« Reply #12 on: 2010 May 12 08:01:51 »
Right but that assumes constant LP. In my case that would be a substantial assumption that probably wouldn't hold :)
« Reply #13 on: 2010 May 12 08:03:50 »
LP is an additive effect. Once you substract it from the the image, you should get the right colors.
(Does you see the catch here? :D)
« Reply #14 on: 2010 May 12 10:03:53 »
LP is additive yes. How does that contradict what I wrote? LP is not constant even if it is additive, certainly not for me. Imaging South gives me much more LP than imaging towards the Zenith. As I track an object LP will vary considerably per exposure. Not just the amount but also the angle of the gradient. The resulting stack has an 'interesting' LP component that can't be removed nor compensated for by filter calibration. I wish it was that simple :)
