www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
Software Development
New Scripts and Modules
StarStatistics class and ReadPSF process module
« previous
next »
Print
Pages:
1
3
4
5
Author
Topic: StarStatistics class and ReadPSF process module (Read 36233 times)
netwolf
Newcomer
Re: StarStatistics class and ReadPSF process module
Reply #60 on:
2011 July 12 04:51:27 »
Carlos,
Yes I am running PI.
Thanks jusd downloaded all your Developmetn modules from your other link. Will try them and See. Now I note CMSegmentation module seems to include ReadPSF, so do I still need to install that seperately?
BTW is it possible to store Dev modules in a seperate BinDev folder? Or must they be in \pixisnight\bin\?
Thanks and Regards
Fahim
Logged
Carlos Milovic
PTeam Member
PixInsight Jedi Master
Join the dark side... we have cookies
Reply #61 on:
2011 July 12 05:00:39 »
No. Just install that module. It is compiled with the latest PCL release, so it should work without problems in PI 1.7. The module that is in this threat is an older version, outdated, and no longe compatible.
Yes, they could be installed anywhere. You just have to select the appropiate folder when you are installing them with the module manager.
Looking forward for your feedback
Logged
netwolf
Newcomer
Reply #62 on:
2011 July 12 18:45:28 »
All is good and working now. I noted that all you modules do not go into any Process sub-menu's. They all appear only the "all process" menu.
ReadPSF is great little tool I worked out how to use it but it would be great if it could automatically find the stars and give you an Average FWHM value. Or maybe let you select multiple stars (of similar size) and give you a average FWHM from those.
I am currently also in parrallel looking at SExtractor, tried to compile it on Mint Debian but it was just going nowhere to many dependencies missing etc etc. I will try on a Fedora VM i have ass there is a RPM for it.
BTW will these DLL file from the other thread work in Linux also for PI?
Logged
Carlos Milovic
PTeam Member
Reply #63 on:
2011 July 13 06:49:42 »
No, for Linux you must use the .so files. I've compiled everything for Linux 64bits, and the latest PCL/PI release. My computers run Fedora both at home and at work, so it is my main development platform.
Logged
Print
Pages:
1
3
4
5
« previous
next »
