Author Topic: Public poll "Name the process"  (Read 6945 times)
« on: 2010 May 03 10:12:00 »
Hi guys
This week I'm retaking an old project, which I am very anxious to get finally done :)
The first project name was "SuperCurves", and then changed to "MultivariateCurves"... but I don't feel comfortable with either one.
So, here is an open poll to put a name to this new process. Basically, it is a generalization of the ColorSaturation tool, mixed a bit with Curves. Imagine that you may create a boost curve (like ColorSaturation) but with any pair of channels (on any supported color space). For example, change the luminance by the hue, or the greens by the blues. The interface will be basically the same of ColorSaturation, although expanded to create all the pairs. Also the algorithm used to boost the channels will be different, not a linear factor (so a Hue/Saturation pair will yield slight different results for the same values/curve).
Cross your fingers so this process will be avalaible in the next release.
Offline RBA
    • DeepSkyColors
Re: Public poll "Name the process"
« Reply #1 on: 2010 May 03 17:21:08 »
Here's a few suggestions that probably don't make any sense...
CouplingCurves
JoinedCurves
PairedCurves
CurveCombine
CurveCrossing
« Reply #2 on: 2010 May 03 23:43:51 »
What about
ColourSpaceCurves (CSC)
After all, isn't what you are doing is applying a 'Curve' transformation via a pair of elements extracted in one of the Colour Space models?
Just my first thought . . . . .
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #3 on: 2010 May 04 01:19:06 »
CombinedCurves
InterChannelCurves
V.
« Reply #4 on: 2010 May 04 06:04:25 »
Thanks for the input you all!
Vicent, I think that you nailed it with ICC. Descriptive, yet simple. I'll use that name for the moment. :)
Offline RBA
    • DeepSkyColors
« Reply #5 on: 2010 May 04 13:15:00 »
Yup, I like InterChannelCurves as well. Just be careful using the abbreviated "ICC" version ;)
« Reply #6 on: 2010 May 04 13:49:28 »
That's one more reason I liked it ;)
