Author Topic: windows configuration for pixinsight  (Read 3499 times)
Offline shurik
« on: 2010 April 03 18:23:46 »
I have purchased the custom desktop PC with windows service pak 2 installed manually. When I am trying to run Pixinsight for the first time it says "the application has failed to start because the application configuration is incorrect" . I downloaded trail version for 32bit platform. Any ideas how to fix this ???
Offline Philip de Louraille
Re: windows configuration for pixinsight
« Reply #1 on: 2010 April 03 20:12:20 »
The obvious thing is to first make sure you have the very latest M$soft OS patches and that includes installing SP3.
Philip de Louraille
Offline shurik
« Reply #2 on: 2010 April 03 22:35:02 »
I don't think pixinsight exe core file is " windows patch" dependent, it says in the instructions that you must have SP2 or later version, so I have SP2, it must be something in bios or command line or registry of the computer that I have to run or make sure its running prior to core application, someone in the development team should know and I am waiting on their reply ...hopefully soon..:)
« Reply #3 on: 2010 April 04 00:41:48 »
Hi shurik,
This is a known problem with Windows XP and PI 1.5.9. I assume your PC has Windows XP installed, although we also have seen this on a couple Windows Vista machines. Here's the solution:
http://pixinsight.com/forum/index.php?topic=1496.msg8132#msg8132
Let me know if this fixes the problem.
Offline shurik
« Reply #4 on: 2010 April 04 12:38:06 »
it works ! might be a good idea to post this link next to download link in download section with the a note for XP users
