Author Topic: What Tool for Removing Blooms?  (Read 9523 times)
Offline sreilly
« on: 2010 March 29 07:51:52 »
I searched the messages and could not find any addressing bloom removal. Is there a tool for this or one coming in 1.60?
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline Jack Harvey
Re: What Tool for Removing Blooms?
« Reply #1 on: 2010 March 29 08:24:56 »
I usually remove blooms with Maxim batch processing prior to working in PI.  Other than that I have also used the clone tool, but you really need to magnify the bloom and work carefully.  It is not convenient for a large number of bloomed stars.  I know a bloom tool has been discussed and is on the wish list
Jack Harvey, PTeam Member
« Reply #2 on: 2010 March 29 08:36:58 »
Not yet. But we have a deblooming tool on the drawing board. This is under experimental development and this is the first time I post these tests here on the forum.
Before - bright blooming
http://pixinsight.com/tmp/20100205/01.jpg
After - bright blooming
http://pixinsight.com/tmp/20100205/02.jpg
Before - dark bloomings
http://pixinsight.com/tmp/20100205/03.jpg
After - dark bloomings
http://pixinsight.com/tmp/20100205/04.jpg
The preliminary implementation is promising but I have absolutely no time schedule available :)
Offline sreilly
« Reply #3 on: 2010 March 29 11:20:07 »
Jack,
I too have removed blooms in MaxIm but using Ron Wodaski's Bloom Removal plug-in which works much better in my opinion. The issue is that when the data is combined and stretched, the stars are usually a little flat on top or there is a slight spike left. Usually I just bring the image into PS and use the Smudge tool to correct this. Maybe I'm missing an important feature but I don't see how I can see what the intended use of each tool/process is. This probably goes back to my very first post in looking for a glossary of terms. Something along the lines of:
Image Intergration: Tool used to combine multiple images into one using Average, Median or other method
Screen Transfer Function: A non destructive means of displaying the image data, use auto for a good start
Dynamic Background Extraction: Process used to remove gradients from the image
and so on........
This would just make it a bit easier to find the proper tools/processes to apply to processing the image. At least for those of use that are familiar with image processing using other software. Listing them as a basic or advanced tool/process would be benifical as well. Just some thoughts.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline sreilly
« Reply #4 on: 2010 March 29 11:21:12 »
Juan,
That bloom removal shows excellent results. Looking forward to the new release!
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline arvidas
« Reply #5 on: 2010 April 04 11:37:38 »
Hi Juan,
That tool for blooming removal looks nice, specially for dark blooming. I am really interested on it because dark blooming is one of the problems I have when imaging with my Orion Starshoot DSI color v2. I have not still found any software for fixing it. Some times I use the clone stamp tool of PI, but ... it is not good enought.
Regards.
Fernando ;)
« Reply #6 on: 2010 April 17 12:54:06 »
Somehow I missed this thread! Very nice results, Juan. Are you using Greyc as base?
Offline Neil
« Reply #7 on: 2012 January 06 12:26:38 »
Is there anymore news regarding this function - deblooming????
MaxIm DL can do this but its very heavy handed and the results aren't great.
It because of this I'm looking at CCDstack, it has a very nice deblooming function.
Any chance this can be put out for beta testing???
Best regards
Neil.
Offline sreilly
« Reply #8 on: 2012 January 06 12:44:16 »
Some time ago it was decided to drop the development of this tool. Seeing how you use MaxIm I'd suggest using Ron Wodaski's DeBloomer add-on for MaxIm. It's posted here http://www.newastro.com/downloads/products.php and works for version 4 & 5 just fine. I've used it for a long time with my ST10XME. This is a free add-on so give it a try. Best I've used including CCDStack's method.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline Neil
« Reply #9 on: 2012 January 18 07:53:00 »
How do you use it with MaxIm 5???
I couldn't get the plugin to work at all any tips would be appreciated.
I still cant really understand why they have dropped development of such as obvious tool for astro-imaging?
Regards
Neil.
Offline sreilly
« Reply #10 on: 2012 January 18 08:16:21 »
Regards
Neil.
What couldn't you get to work? You installed it so it shows up in the Plug-in menu OK? There is also the debloomer pdf file, did you get that? Do a search for deblooming and you'll see the whole thread. Forget that, this is that thread! Link found for the PDF file is here http://elynxsdk.free.fr/datas/debloom/debloomer.pdf
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
« Reply #11 on: 2012 January 18 09:39:01 »
Maybe there is a volunteer who implements the algorithm that is pointed to in http://pixinsight.com/forum/index.php?topic=1300.msg6616#msg6616 ...
