Hi Steve,
I downloaded your R,G, and B masters into PI and created a RGB image. The color balance immediately after combining is off(magenta dominated), but after processing the colors look good/proper. I've tried to attach a jpeg of the processed result. Not meant to be a finished image, just to show that PI does a great job getting color balance right. The critical steps are DBE and Color Calibration. After these the color is mostly corrected. Then one can fiddle with color saturation boosts etc.
The steps I followed are:
1. Auto Histogram applied to each color master using the default settings. I believe this sets the black point for each image.
2. Channel combine to create the RGB master Image.
3. Apply the STF to the RGB image. This allows you to see the image and still keeps the data linear which is necessary for the initial processing steps. The color balance at this point looks wrong but that will get fixed.
4. Use Dynamic Crop to get rid of the bad looking edges that result following image registration.
5. Apply DBE. Juan's video tutorial on DBE available on the PI web site along with Harry's video are great guides to using this tool.
6. Apply Color Calibration. This is the critical step that will correct the color balance. Harry has a great video tutorial for this step. You can also do Background Neutralization at this point though I didn't for this exercise.
7. Apply SCNR to remove any excess green,
8. At this point can reset the STF and then apply a non linear stretch with the Histogram Transformation.
9. I used Curves to apply a slight color saturation boost.
I'm still a beginner with PI so I don't claim this is the best or only way to process this image. Just wanted to show you how you can get more correct color. I'm finding that the G2V derived color ratios used to create RGB images in programs like CCDStack or Maxim don't seem to be needed in PI. In PI, I combine the R, G, and B images 1:1:1 and then get more correct color balance with subsequent processing steps. Hopefully others will chime in to give you more suggestions.
