Author Topic: HRDWavelet: Different Results on Preview vs. Full  (Read 5639 times)
Offline andyschlei
    • http://www.obsballona.org
« on: 2007 April 10 17:10:19 »
In working on a galaxy image, I used the new HDRWavelet Transform and tweaked the parameters until I got a nice result.  I then applied the same statistics to the entire image and got much different results.  Where the medium scale features were enhanced in the preview, they disappeared in the full image process.
In the end, I cannot get the good results visible in the preview in the full image.  I cannot even get anything close to the preview in the main image.
I tries this on a larger preview, and it matches to the results of the main image, so there may be a scale issue with the smaller image.
I'd be happy to post FITs if needed.  I can also provide screen shots.
--Andy
Observatorio de la Ballona
CDK 12.5, NP-101, C-11
AP-1200, AP-900
ST-10 XME, CFW-8, Astrodon v2 filters
Pyxis Rotator, TCF Focuser
« Reply #1 on: 2007 April 10 20:42:37 »
Hi Andy
Yes, we are aware of this issue... and in fact we have found to this date anything to "fix" it. Let me explain the problem. HDRWT works in a multiscale way, modifying not only the weight of the wavelet channels, but changing the contents of each wavelet layer with respect with other wavelet layers and residuals. So, if you have a preview that covers only a partial zone of the image there will be different contributions to the whole computation, and the result may (well, almost surelly) differ from appying the process to the main image. Something related happens if you try the process on a subsample version of the image...
So, we have to find a way to make previews to give an accurate result, without the need of applying the process to the whole image, and it is not easy. Meanwhile, I suggest you to try as a first approximation a 2x downsampled version, and then fine tune the result with a preview with the same contents/size as the main image.
Thanks for the feedback!
