Author Topic: M33 Revisited - Fooling around with HDRWavelet - Wow!  (Read 6648 times)
Offline Luc Coiffier
    • http://deepskystacker.free.fr
I couldn't resist trying the new HDRWavelet and decided to give it a shot with my M33 shot. :D
The last time my best post processing effort was that.
This time I got this, almost by just following the small tutorial in the breaking news (30% reduction)
The full size is visible here (warning 7Mb image!)
I know that there is still noise (although I did use GREYCstoration) but I don't mind it since it is not destroying the image.
Thanks a lot to Vicent Peris for the algorithm and thanks to the PTeam for implementing it.
It does wonders: a lot of hidden details are now visible.
Trust me: give a new post processing to your old images and you will be amazed. :D
BTW, I have a small request to Juan: would it be possible to save the history of an image with the image (or in a separate file or something).
Clear skies,
Luc
« Reply #1 on: 2007 March 31 14:36:06 »
Hi Luc
Congratularions for your new result. It is simple a big jum ahead. :) Just take with more care the stars next time ;)
Regarding the history question, you have access to the whole Processing History throught the History Explorer. If you look at the bottom, you'll see a "drag and drop object". If you drop the history on the workspace's background, you'll create a new Process Container, with all the processing steps in the History (in fact, histories are a subclass of process containers). This icon may be saved just as any other into a .psm file.
« Reply #2 on: 2007 April 01 05:14:08 »
Hi Carlos,
I know about the stars (big, blotted...). I simply did nothing to process them.  :oops:
I was so thrilled with the result of the HDRWavelet that I forgot about them completely.  :wink:
Thanks for the tip about the history. This was exactly what I was looking for and much more.
In fact my process workflow involves a lot a previews which are transformed to images when I am happy with the result.
To be able to create a ProcessContainer containing all the small steps to replay them later all at once will simplify my post processing.
Clear skies,
Luc
