Author Topic: How can I access to controls in a tabbox page?  (Read 6076 times)
Offline Silvercup
« on: 2010 February 27 13:13:29 »
Hi I need help:
I need to update a Edit control inside a tab page. How I can access to the control?
I can do ->  parent.tabs.currentPageIndex and return the active tab index.
Thanks. Silvercup
Re: How can I access to controls in a tabbox page?
« Reply #1 on: 2010 February 27 18:49:14 »
I don't know if I can help you at all.
However, about a year ago Juan sent me the following code snippet to help get me going with <TABS> in PJSR, but I never had time to pursue things. Perhap it may be of 'some' use to you, I don't know
#include <pjsr/Sizer.jsh>
#include <pjsr/FrameStyle.jsh>
#include <pjsr/TextAlign.jsh>
function RandomChars( howMany )
   const c = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
   const n = c.length;
   var s = new String;
   for ( var i = 0; i < howMany; ++i )
      s += c[Math.round( Math.random()*(n-1) )];
   return s;
function MyTabPageControl( parent )
   this.__base__ = Control;
   if ( parent )
      this.__base__( parent );
   else
      this.__base__();
   this.helpLabel = new Label( this );
   this.helpLabel.frameStyle = FrameStyle_Box;
   this.helpLabel.margin = 4;
   this.helpLabel.wordWrapping = true;
   this.helpLabel.useRichText = true;
   this.helpLabel.text = "<p>This is a Control object inside a TabBox.<br/>" +
                         "This is a random string:<br/>" +
                         RandomChars( 40 ) + "</p>";
   this.targetImage_Label = new Label( this );
   this.targetImage_Label.text = "Target image:";
   this.targetImage_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   this.targetImage_ViewList = new ViewList( this );
   this.targetImage_ViewList.getAll(); // include main views as well as previews
   this.targetImage_ViewList.toolTip = "<p>This is just an example.</p>";
   this.targetImage_Sizer = new HorizontalSizer;
   this.targetImage_Sizer.spacing = 4;
   this.targetImage_Sizer.add( this.targetImage_Label );
   this.targetImage_Sizer.add( this.targetImage_ViewList, 100 );
   this.sizer = new VerticalSizer;
   this.sizer.margin = 6;
   this.sizer.spacing = 6;
   this.sizer.add( this.helpLabel );
   this.sizer.addSpacing( 4 );
   this.sizer.add( this.targetImage_Sizer );
MyTabPageControl.prototype = new Control;
function MyTabbedDialog()
   this.__base__ = Dialog;
   this.__base__();
   this.pages = new Array;
   this.pages.push( new MyTabPageControl( this ) );
   this.tabs = new TabBox( this );
   this.tabs.setMinSize( 400, 200 );
   this.tabs.addPage( this.pages[0], "First" );
   this.tabs.addPage( this.pages[1], "Second" );
   this.tabs.addPage( this.pages[2], "Third" );
   this.tabs.addPage( this.pages[3], "Fourth" );
   this.okButton = new PushButton( this );
   this.okButton.text = "OK";
   this.okButton.onClick = function()
      this.dialog.ok();
   this.buttons = new HorizontalSizer;
   this.buttons.addStretch();
   this.buttons.add( this.okButton );
   this.sizer.add( this.tabs );
   this.sizer.add( this.buttons );
   this.windowTitle = "TabBox Example Script";
   this.adjustToContents();
MyTabbedDialog.prototype = new Dialog;
var dlg = new MyTabbedDialog;
dlg.execute();
Offline Silvercup
« Reply #2 on: 2010 February 27 18:58:20 »
Thanks for your support Niall.
With some trials I have found it. You can acces this form:
parent.tabs.pageControlByIndex(0).Ltext_Edit.text=""
Where tabs is the TabBox object and Ltext_Edit is the Edit object control which is in the first tab (first page) i.e. pageControlByIndex(0).
You can acces to controls on secont tab simply using pageControlByIndex(1).
Best. Silvercup.
« Reply #3 on: 2010 February 27 19:12:15 »
I'll be looking forward to your completed script - adding TABS was the one thing I would have liked to have done with my <Batch deBayer> script (which I wrote out of necessity at the time, but which I also used to help me 'understand' PJSR in the absence of a "How to write PJSR" manual - hence the reason that the code is so long, and so FULL of detailed comments).
In fact, I will be interested to see your final code myself - if only to take your work with TABS and to then comment all the code sections in the same way as I did in my deBayer script!! In fact, despite my code being so camera-specific (for a Meade DSI-IC or -IIC camera), I reckon that Juan wanted to include it with all future 'standard distributions' of PI simply because it WAS so fully commented.
