I first successfully ran the HDRScript with the default settings to combine 3 fts files generated from PI itself. The files are originally 3 DSS stacks of different exposures for M42. HDR worked although i am not happy with the results. (i will post a second thread for HDR help)
So now i am trying to play with the parameters and its crashing.
Error message is:
*** Error [000]: c:/.../HDCCompoistion.js LIne 399 at address 14002CBA3 with exception code C0000005.
Access violoationL invalid memorhy read operation at address FFFFFFFFFFFFFFF
I had adjusted the hightlight and low lights. Up'ed the mast to 4pixels and set the mask growth to 2.
I also enabled postprocessing options with the defaults: balance .0005, HDRWT Layers 6, interations 1, Enhance colors checked.
I am not sure it matters with all this Java stuff, but i am running Windows 7 with 4GB or ram.
