Author Topic: Pixel Math and Masked Images  (Read 8224 times)
Offline Jack Harvey
« on: 2010 February 08 16:39:35 »
What happens when you combine two images in Pixel Math and one of the images has some data masked?  Is the masked data excluded from the combine, or is the mask ignored?
Jack Harvey, PTeam Member
Offline NKV
Re: Pixel Math and Masked Images
« Reply #1 on: 2010 February 08 20:19:42 »
PixelMath ignoring masks on sources. But result applied via mask if destination's image have a mask.
« Reply #2 on: 2010 February 09 00:00:11 »
I think that is the standard approach made by Juan in all cases - masks are only applicable to a 'destination' image.
Perhaps Juan will get a chance to confirm this.
« Reply #3 on: 2010 February 09 00:38:59 »
Nikolay has described it accurately. As Niall has pointed out, in general masks are transparent to processes in PixInsight. This means that a process does not care about its target image's mask. The core application filters a process' result through a mask, if there is one active and enabled, after process execution. This is coherent with PixInsight's object-oriented, modular architecture and design: processes and images are independent objects. From the user's perspective, by separating process execution from masking we gain in modularity and hence in reusability (the same process instance can be applied through a different mask) and versatility (it is much easier to compare the result of a process with and without a given mask if process execution and masking are separate, unrelated procedures).
In the case of PixelMath, you can use the target image's mask with the $M (or $mask) metasymbol. For example, the following expression:
$T*$M
will multiply the target image by its current mask, or will yield a runtime error if there's no mask selected for the target image. Note that if the mask is currently enabled, the result of the above expression will also be masked. If the mask is disabled, the result will be the plain multiplication (possibly rescaled if the rescale result PixelMath option is enabled).
Offline Jack Harvey
« Reply #4 on: 2010 February 09 06:21:48 »
Got it, thanks guys!
Offline Dimitris Platis
« Reply #5 on: 2013 May 22 10:55:10 »
Suppose u want to multiply the target ($T) with the inverted mask and not the normal mask.
How do u formulate that in Pixel math?
« Reply #6 on: 2013 May 22 12:50:16 »
$T*(~$M)
