got up at 3 to check the clouds...
Listen,Harry,group; a couple of things if I may,...
First I admit I have been an "ABE aholic"...I am ashamed
but its true...I have been "using" it MANY times a day even..sometimes in the morning...!
But when I try to use DBE (it takes practice I am sure..)...it never seems to draw the little boxes ALL over the background...
I spend like 5 minutes clicking away,moving them OFF the nebuala etc.
Is the trick to click on ENOUGH different "samples" to get it thinking clearly,before hitting generate...or am I missing something more...?
SECONDLY....
When I apply the "background neutralization" to any residual problems...(GREAT TOOL...thanks Harry...how did I miss that..??)
It can give me an EXTREMELY "tight" result...
I mean all the data is "squished" into a peak on the far left....
This is good in a way...but maybe too much..!! (for example it is hard to build a Lum mask from such tight data,,,)
Is drawing smaller/less background samples better...Maybe not drawing them in the WORST areas...or..??
One last quickie...(one last time);
I should chuck the data (RBG) AS OBTAINED out of DSS (in my case..) RIGHT into registration and RBG combine...?
EVEN if the histo's are slightly different,etc,etc.
No questions...just chuck it in..
What if I have collected more/better subs in BLUE (for example)...and it is less "noisy"...ie stronger...just put it in the pot..??
What if I am deciding to use 2.7 minute green subs,and 3.2 minute Blue...( for balance)...
Chuck them straight together...??
Thanks again....I feel I am being a real motor mouth...(but I am...)
Dave
PS here is my re/re/redo of M51...
Took about 10 minutes total..(!!)
http://www.flickr.com/photos/daveh56/4300139602/sizes/l/(I like blue...)
